Finding TDC for all cylinders?
e9999
Gotta get out there...
Moderator
US
planning to do a leakdown test before too long. Just for fun, nothing wrong with the engine.
So, gotta find TDC for each cylinder. But I'd rather not take the valve cover off. So checking with you 1FZ fiends to minimize trial and error.
TDC/Closed valves is easy to find for cyl 1 I'm sure: put the cranckshaft pulley mark on the 0, figure out if valves are closed (e.g. is the cylinder holding some pressure?). Is so, good, if not go one revolution further. OK.
Now the other ones.
Firing order is 1 5 3 6 2 4 IIRC.
Firing for a given cylinder is every other revolution, being a 4 stroke.
I imagine the 6 cylinders are all fired over the course of 2 revolutions, not one, for smoothness. Is that right?
So, if I go 120deg past the cyl 1 closed valves TDC, I should be at closed valves TDC for 5, right?
Another 120 for 3 and so on?
And what's the socket size for the cranckshaft nut if you recall?
TIA
Dunno if this helps or not, but here's the FSM for checking valve clearance. It details how to set TDC. It seems like everything goes on just two revolutions, so I would think you could set it to 0, test half the cylinders, spin it 360*, test the other half. I may be making it too simplistic though. :meh:
interesting, not too sure what to make of that (besides the fact that I am not looking forward to adjusting my valves, and what's with that number 6?).
It does indeed look like you can measure most valves (not 6?) with just 2 crankshaft positions. Now, of course, that does not mean that you have 3 pistons all the way up at TDC at the same time since the valves will be closed over a significant duration and may overlap some. Clearly, the distributor tells us that you don't have 2 pistons firing at the same time. Interesting, though. This would suggest that if you have valves closed on more than one piston at the same time you could do a leak down test that would work on the valves, and HG side for those cylinders without spinning the shaft. For the ring side of the test, I would think you'd want to be really at the TDC, tough. Another issue if you're not at physical TDC is that you may make the engine spin more easily with the compressed air.
Eric, I'm bored today and just don't feel like wrenching even though I have plenty to do.
I'll make you a template that you can use for this. I'm thinking a cardboard template that will go over the distributor and sit on the ledge where the cap seals. It will be marked for the firing positions and numerically sequenced to the firing order.
The idea is to remove the cap, rotate the crank to TDC of #1, place the template over the distributor and align the rotor with the #1 position. That way when you are done with #1 you just rotate the crank so the rotor points to the next position and test that cylinder.
What do you think?
What do you think?
you're doing great work with cardboard :) (were you an origami master in kindergarten?) so anything you'd propose to do we should jump on. Great! Thanks.
But so, first, am I right that the 120 bit is correct and a good way to go?
If so, your idea is great, should be easily visible (if with a mirror for the low side) and easy to set up. One thing coming to mind, though, is whether you think that the distributor way is going to give us enough resolution given that the rotor is quite a bit smaller than the pulley? And seems like your zeroing would take care of the static advance timing even for folks who have it set to more than the 3 deg. Nice too.
An alternative would be to just mark the pulley every 120? How about a cardboard disk or strip with the degrees marked on it what we would attach to the pulley somehow and match with the timing mark? Although if the disk is on the front of the pulley it's probably 2" away from the mark so less easily aligned. Of course one could do all that with a piece of tape and a sharpie, but much less elegant.
Eh, this may turn out to be fun! A new gadget! All right!
How 'bout this...if your tester has the ability to disconnect the spark plug adapter thread it in #1 cylinder. As you bring it up on the compression stroke while holding your thumb on the hose you'll feel the pressure build. Once you reach TDC you'll be able to rotate the crank back and forth and feel or hear the air movement in and out of the hose to nail down where you need to be. Do the same to each cylinder as you work your way through the firing order. It sounds more complicated than it really is.
Make sure when you're ready to perform the test that you set it up ans you are rotating the crank in the normal direction which will ensure the rings are seated as they would be when operating.
yup, sure that would work in principle, if I can reach both socket wrench and plug hole or hose at the same time. Would tell me if the valves are closed and then I can use a dowel to nail down TDC better. I can also figure this out with a compression tester of course, then I don't need to do gymnastics. I don't know how long in degrees the valves both stay closed -probably quite a bit- but they must be fully closed for the test to work, of course. You also want to do all the cylinders while warm, so I don't want this to take 1 hr with a bunch of trial and error to slow me down.
Seems easier to turn the crank by a fixed amount of degrees and know ahead of time that the piston is where you want it to be, though, don't you think?
Will anybody confirm the 120deg bit or am I completely offbase here?
You're making this way too complicated, it's really not that hard.
Yes Eric, the 120 degree thing is correct. Each 120 degree rotation of the crankshaft will bring up the next cylinder in the firing order. two pistons on a 6 cylinder engine are always moving in unison, the ones that are 180 degree opposite on the firing order. (180 degree looking at the distributor, 360 degree looking at the crank). One is at TDC compression stroke, the other is at TDC exhaust stroke. The former will have both valves closed, the latter will have the exhaust valve open.
When I've needed to determine where the accurate TDC or BDC is, I've used a long piece of coat hanger stuck down in the hole. Too long to drop down and get lost, and won't do any damage to the piston or walls. Or a wooden dowel (artist paint brush is very good too) Very easy to pinpoint TDC this way. Then the only thing to determine is which of the two TDC pistons you're looking at, the compression or exhaust stroke? Open the distributor and see which wire the rotor is pointing at, that's your compression (also power) stroke cylinder, and the first one to measure. Then, simply rotate the crank around stopping at each 120 degree position, and measure the next cylinder in the firing order. Two fulls turns of the crank and you're done. You can mark the distributor with chalk each 120 degree and rotate until the rotor points there, then pinpoint your exact TDC using the dowel method. Very fast doing it this way.
Dana
I think what I may do is spend some time figuring out the 120 deg on the pulley as accurately as I can and then mark it permanently with paint and stamp or grinder so it's there for good and I won't have to futz around with the dowel any more in the future.
Don't take offense, but this is being blown out of proportion to the point that performing the leak down test could have been completed by now. If there is this much work involved you might as well get the cylinder as close to TDC as possible and reinstall the remaining 5 spark plugs to help keep the crank from rotating. Think like Nike, "Just Do It"
hmmmmmm.... maybe i'm wrong and a leak-down test is different than a compression test. I did a compression test on my truck a year or two ago and what i did was to remove the plug on the cylinder i was testing, pull the EFI fuse so no fuel was being dumped in the cylinder, turn the key on for just a second, take reading, move to next cylinder.
I'm thinking a leakdown test is different......
ummm.... no, nothing complicated. Just will do what I suggested in the OP. Merely asked for confirmation that it's 120 deg. Personally, I'd rather have the pulley marked than futz around with feeling air, compression testing or dowels. (Although LT's template would be elegant all right.)
yes, it's different. Kinda like a compression test turned the other way around. See thread on the HF leakdown tester if you're curious.
Of course, once you have removed all the junk from the head, you might as well do both tests in succession.
well, I did a leakdown test.
I ended up not doing an accurate marking of the pulley every 120degs. I just used a dowel and stopped when the dowel was indicating I was at the top. I went around 3 or 4 times to see how repeatable the TDC estimate was. Not bad. Within 10deg which should be good enough to have the valves closed I would think (and hope). I marked each guessed TDC. So now I don't have to use the dowel any more.
The bolt on the pulley is 30mm for what it's worth. Of course, I didn't have one of those...
so what were the numbers on the leakdown?
Easy enough........ cut the center out of an old distributor cap and install it.......
A really true leak-down is with the valve adjusters backed off so not to interfere and piston location tested in at least 3 locations......top, center and bottom of the stroke..... Help answer the question "Could the cylinder bore be TAPERED"?......just gives a more accurate idea of whats going on...... cyl wall conditions can vary and have leakage at the bottom or in-between........
