fender flare gaskets
brownbear
Mod in Hibernation
Moderator
Hamilton, Ontario
So my beige/tan 91 80 has loose looking fender gaskets, parts stick up and are not really doing anything.
I was going to remove the flares and clean the area, then spray some corrosion proofing in there and re-install the flares.
So my question is... are tan/beige fender pads(epc term) easy to find/buy? How much $$
I am thinking of a re-paint in a year to white, so I was considering just going with black gaskets , as they may look good with the white.
Anyone have black gaskets on a different colour?
Are these gaskets paintable? or would I need to buy new white ones later?
Cheers, BB
Gaskets are available from Cdan at American Toyota for around $60-65 for a set of four IIRC.
Not really paintable. They might still be available in your beige (4k1) or the white (045). In just the last couple of years Toyota has played around with the part numbers, probably because stock is low and no more are made. There were different p#'s for black depending if the truck was black or green and left or right side. Now I think there are no seperate numbers for left or right or black or green.
edit -- The numbers are also different from '91-92 which I can see since the flares where slightly different but the '93-'94 are also different numbers than '95-'97
Does anyone know what changed after 92 on the flares?
The EPC I have at home is a japan/europe one. It only listed four colours; black, maroon, white, and beige.
Yah I have one blowing in the breeze.
My wife likes the look of the flares...I do too, but not at the expense of rust problems. The roads is slushy here now and I can see the sh_t going in there. I may pullem and plug the holes to prevent rust.
hmm, I will have to look at some pictures of different year 80's.... I never knew there was a difference. I am kinda glad my 80 has narrower flares as I run 235/85 r 16 tires.
AFAIK, the flares got wider in '93 and the mounting locations changed in '95. The material also changed to plastic in '95.
I take back what I siad above. Looks like some of the rubber extends from '93-'97 but the numbers change because of colors that didn't make it all the years. The '91-'92 have their own specific numbers.
Beige 4k1 part# for the front is 53851-60020-05.
Back door in beige is 61783-60010-05 for left or right side. HOWEVER the new number shows as 53851-60020-05 which is the same as the front. My guess here is they no longer have a specific piece here so you might have to cut to fit with the new number.
This is the same for the back quater panel. The old number for either side was 61784-60010-05 which is replaced with the same front number of 53851-60020-05
The small pieces on the inside of the door is black and 90999-91053 for the '91-'92. This is the same number for the small pieces on the inside of the quater panel.
thanks very much for all that info.
I will have to tackle this job soon. good to know about the cut to fit.
Really? Is that for all 4 flares, which would be a total of 6 pieces? Longo Toyota is charging $150 for 6 pieces of flare gaskets:frown:. If so I need to contact Cdan ASAP.
Thanks
Ray
I just bought one gasket to replace but not overly confident of removing the flare w/o doing some permanent damage!!!
Bushwacker makes a black trim gasket that I was learned about last week. I can not find any reference to it on their website but I know that I can get a box (aprox enough to do all four fenders) for about 40 bucks. I will try and find the part number from the my local offroad shop. They had it in stock but for the life of me I can't remember the part number.
I recently acquired a white 96 FJ80 that I am hoping to paint the fenders black and will need to do the same thing it sounds like you are trying to accomplish.
Hope this helps and good luck!
Remove the front marker lights to reach some of them, go through the holes inside the engine bay for the others. I just removed mine yesterday. I searched some old threads " removing fender flares" in the 80 tech section.
I replaced the gaskets when I rhino-lined the flares. I got them from Dan and, in hindsight, I wouldn't do it again. They are fairly expensive, although I don't recall exactly how much, and the first time you pull a flare off you lose the gasket. Now I run a bead of black caulking around the flare and it looks just fine.
Thanks
Ray
You will ALWAYS get a better price from Dan! Better service and advice as well! To the best of my aging recollection, that was the approx price.
if you find the part number please post it up.
