Feeling good after wheel #1
Kennedrunksnort Maine
I'm a rookie and trying to clean up my new rig so working up and will post more pics soon...it's dark and the Sox just won!!!! The rattle cans worked well-Duplicolor graphite 102 with multi-coats of laquer and I figure while I was ther, do the calipers(I know..overkill but it did perk things up. So far, so good. Sand, prime, rattle and laquer. Don't forget step#6(plenty of hops and barley).
I did the same with the oxidized rims on my mini. The paint can rub off but touch up is really easy. I need to redo one of my rims. I lost a bead running 8psi and the edges got polished back down to the aluminum. Easy fix. People keep asking me how I like my Teflon rims. I just laugh and tell them its spray paint.
nice!
how did you sand the surface? did you have to remove all the clearcoat or just roughen it up?
320 grit sandpaper, elbow grease, 2 coats of primer, 4-5 coats of the graphite paint and 5 coats of laquer. Used a hair dryer while doing the coats which really seemed to help speed things up. Did the primer on the calipers, caliper paint and 2 coats of laquer. I tried it on my winter set of subaru outback rims and liked the result. Did a metal flake gold to match the body moulding on the outback. You have to rough up the sheen or the paint won't take well.
Wow, that really looks nice. I wondered about painting the calipers (and hub and knuckle) while doing my front axle rebuild recently - I just couldn't bear the thought of bleeding the brakes again though. :crybaby:
Anyone have thoughts on how this could be done with a more permanent solution? How do custom wheel shops finsish wheels?
Great look - waiting to see full-vehicle pics.
Soon on more pics--just came in from Magic Mendering the drivers side seat w/ their leather dye. We'll see in the morning. One wheel to go. Nuts are on solid-liquid wrench and still not budging-got to impact wrench it or something. Re-did the rear bumper ends. Next up, finish the dye-job to the fronts, add the spare tire rack to my Yak rack w/ rocket box, door panels out for new 6 1/2" infinity 6022 si shallows in the front and eclipse 5 1/4" in the rear. Can't quite pony up more cash on new deck and sub/amp yet but if I could do it again, I'd probably advise others to look at JL Audio for speakers and amp combos...amazing sound and imaging. Thanks for the applause on the paint..GO SOX
