i have a 1997 hzj75 ute. it has 9.5 rear and small high pin front. from what i have found the front diff is the same as an australian hilux ute, for which there are 3.7 gears. the intended solution for less rpm at 100k's is a 60 series rear and a hilux front to supply the gears (3.73)
The issue with your front diff it's High Pinion .. reverse cut setup .. and the hi lux not ..
