fast idling
Winston Oregon
ha guys. Got a little trouble that i finally need to deal with on my wifes 87 runner. You can be in 3rd gear and it will go down the road with no clutch pushes in 35 miles an hour:D no throttle at all WITH THIS YOU CAN HEAR THE ENGINE RACING DURING THIS. At normal idle it will show 2500 rpm. In the past if you shut down the engine, it would go back to normal rpms after restart..any ideas. the one thing i found out on my old honda that it had a fast idle valve and did the very same thing this rig is doing. but im sure the part is not called the same./possible culprits-temp sencer -egr- and for the lack of my knowlege on these rigs there is a diaframe/plunger under where the throttle bolts to the intake. On this, the boot is cracked. I might need to post pickers sunday on this if nobody knows what i am reffering to.THANKS GUYS:beer:
Did you make the pictures small enough to attach? They have to be under 120 Kb in the jpeg format to attach.... You should check for vacuum leaks in general. They will cause a high idle all the time. It is all the time right?
i will try again this time when down loading it said something wrong with file:confused: anyway maybe i can just email them to ya ya timing is great,vac is ALL GOOD.
Here you go.
That is a dash pot..... it's suposed to slow the final closing of the throttle plate for some emmissions reason I think... It doesn't move much, but should move a little bit. less than 1/8 inch I think.
hmm its hooked to the throttle, im wondering if it sticks would it couse a fast idle.i just noticed when my wife left after being parked over night,it sounded fine:confused: wierd.thanks man:beer:
