Fan Clutch Operation?
Kansastitty
Should I be able to grab the fan and move it (with little resistance) when the engine is stone cold? I thought it only locked up at higher temps?
Sorry about the remedial question, but this my first experience with a fan clutch.
Ed
Ed
Ed,
The fan clutch can always be easily moved by hand. We say it "locks up", but that is not really true. the clutch is a variable torque converter. when cold it allows 95% slippage. when hot, the shutters are moved inside so it now allows 5% slippage.
So at 2000crank RPM, 2800waterpump RPM, the fan will spin 2500RPM hot. that makes a hella noise, so everyone knows the clutch has "locked up". But with the engine stopped, you can easily turn the fan by hand at several RPM.
Jim and Cruiser 88, thanks. I'm just about ready to fire up my new motor and just did not want to cook it whist breaking in the cam and lifters.:)
Ed
It should not just spin freely/more than one complete revolution when trying to spin it by hand when the engine is cold.....
Well, Steve, it does not spin freely, there is some resistance. I guess during initial break-in, I can put a box fan in front of the radiator....then if it does not "lock up" and spin, I'll search for a 'nother.
Ed
Then you should be fine bud!
:beer:
You will here it at start up...and then it will get quiet for a bit...and then it will start to make noise again.....at least it should.
I'm not sure either but I think two things have to happen to activate the fan: heat and centrifical force. When I'm sure if its working or not is warm the engine and shut it down. Hold the fan with your tip of you fingers and have someone monetarily start the engine and shut it down quickly. If the fan catches or you missing fingers it's working. :) This is the idiotic way of checking fan. Kinda like my mechanic used to shock himself when he had no other way of checking if the electical system was working.
