Fan clutch adj temp measuring methods
Alright, for over a decade we've been adjusting and refilling fan clutches.
Most use the water method while some use a thermocouple and a heat gun to make the temp adjustments. I needed to do something to get my brain off the business this evening so I tested all the common ways of measuring. I'm an electrician by trade so I broke out my meter and the thermocouple For it.
What I found with the water was that if the water temp was 130, if I placed the fan clutch in the water and let it sit for 15 seconds when I read the temperature of the coil the coil was about 120*. No matter where on the coil I placed my probe the temps stayed within a 2 degree parameter. I would consider that pretty good.
I then used a heat gun On the coil. I heated it until the ale just started to open. I then checked the coil with my temp probe. From the the center most point to the outer most point (part where coil attacked to clutch) it was consistently 10-12 degrees different.
So what gives, which measurement is the way to go. Hot air would seem to be the preferred way but I don't know where to put the probe or away to keep it consistent s
Rick, Kevin, and other gurus what do y'all say?
sounds like you answered your own question, no?
Yea, I kinda answered my question, but was making sure I wasn't doing something wrong.
Rick, do you use and ir thermometer and the water or heat and ir.
My wife is a cook or chef or whatever. Anyways she saw me messing with it and said "putting it In the stove will work best".
She's gonna love hearing this am I'll prob never hear the end of it.
