Fan Blowing Fuses
Indianapolis
Hello all. I am new to this board and need some help. 78 fj40. I can use the heater fan in low speed but when I pull out to high speed, it blows the fuses that control the small guages such as fuel guage, etc. Anyone have an idea what may be causing this or where to start checking for shorts? Rear heater works great. Thanks in advance.
the switch will have 1 power in and 2 power outs and possibly a ground . the two outs will be hi and lo , test light em and figure which is lo then check the hi line for any shorts in the wire , it could be the wire or internal in the fan or switch , you could unplug the wires at fan and then operate switch to see if it is inside the fan. My guess is the hi line is shorting under dash somewhere.
Thanks...I will check that. Is it possible that I need to do the heater repair that is covered in "Tech Links"? The fan doesn't blow very well and I was wondering if maybe the brushes were shorting out on high speed. Would week brushes also cause fuse to blow?
Somethiing is going to ground (shorting) somewhere. I'd suggest eliminating one thing at a time until it stops blowing fuses. Once you find it-problem 2/3 solved. Get a wiring diagram. Also check any previous owner's modifications/add ons as they may have been done incorrecly or carelesly.
