Faint squeal over 50mph
musthave
All maps, one app!
Supporting Vendor
Florida / Colorado
I'll start with Front knuckles done in last 10K, everything new OEM. All new rear bearings, seals, etc. all OEM within last 10K. 2.5" lift.
When driving down the highway I hear a very faint squeal, but with the following specifics:
1. Only occurs when turning wheel maybe 5° left of center/straight
2. Noise stops when over about 10° left of center/straight
3. When noise occurs going faster or slower doesn't change pitch or consistency
4. Slowing to below 50 or so and the sound stops
5. Applying varying degrees of brake or slight parking brake has no effect on the sound
With right rear window open I can hear it louder, other windows open I can't notice a difference. I went ahead and replaced the seal on left rear but it looked perfect.
I tend to think it's drive train as if it were belts, etc. it wouldn't only happen with with #1, and #2 above.
Any thoughts?
RR wheel bearing. Could be too tight OR too loose. Turning left changes the pressure on it and puts a radial pressure and may cause a bearing cage to drag.
Rock in the caliper?
Hadn't considered the rock in the caliper. Worth looking. I replaced the RR items but perhaps too tight or too loose. I'll take off the wheel tomorrow and check / adjust to FSM. Great suggestion.
