enough with the seafoam. IIRC someone here used it on a carbon soaked engine part and it did nothing to the deposits, and that was with letting it soak overnight and then scrubbing/scraping it. So by passively flowing seafoam through the intake, you aren't going to get a lot of carbon to break away.
Most of the seafoam testimonies I have heard rely on anecdotal evidence as there is no true way to quantify the results unless you pull the motor apart, put it back together without cleaning it, then run seafoam, then pull it again and measure the carbon build up. To my knowledge, nobody has ever done such a thing.
Like someone mentioned earlier, you need to get yourself a bottle of GTP (guaranteed to pass). They sell it at any autoZ/checker. I have yet to see that stuff fail even in the poorest of maintained vehicles. No need to waste more $$ on seafoam. GTP, moneyback guarantee.
Not that I would would advise you to do the following, but doesn't the old "slip the tech a $20" trick work anymore? I did that a half a dozen times when I lived in UT.
