Failed UT emissions
Utah
Some of you may know that I work at a (reputable!!) lube shop. We're a Safety/IM station as well (except me, I'm not certified :rolleyes:).
Well today, I get my own emissions test done, and the computer says FAIL. Over on CO's (junk in the engine I guess). 1991 is allowed 1.20 for CO's, Katie is reading over 3.
Now, a couple weeks ago, I had to replace part of the intake tube because chunks were coming off and going into the engine and melting, causing pre-detonation (my theory). I'm fairly certain that the leftovers are still sitting on top of the pistons as carbon deposits or something, causing these bad readings.
Anyone know a way to help with this? I'm due by the end of the month and don't really feel like getting hassled by UHP...
Water? Seems like I remember that you could inject some water in your intake to remove carbon deposits. Might want to search and see if I'm mistaken.
I got a Porsche 914 through emissions in UT many years ago. There are some tricks you might try, and I am sure there are lots more around on the web--
1) Make sure it is VERY warmed up--get it really hot and don't turn it off while you are waiting for the test to start.
2) Leaner mixture reduces CO and raises NOx. If you have headroom on the NOx output, you might see if you can lean it out. Don't know how feasible this is on our LCs, but removing the air filter can't hurt.
3) Distributor advance
4) New (hot) spark plugs.
5) If you are really worried about carbon buildup, run a bottle or two of Techron or Gumout through. Rev the crap out of it under full throttle (take a trip up Provo Canyon or up to Park City in 3rd). That will burn off anything in the combustion chamber.
6) Not very honest, but ask around with your mechanic buddies and see if you can find a, um, helpful testing station. This opens lots of possibilities, some of which could land you and your mechanic in hot water....
Seafoam is supposed to really do a number on carbon deposits. you can find it in any walmart or auto parts store. IIRC, about $4 a can.
You have to draw it into the head using a vaccum hose off of the intake manifold.
maybe a dumb question, you had it tested at the place you worked, did you drive it around suffecient to get the cats good and hot prior to the test?
I usually change the oil right before a smog test and then drive it to get it really warmed up. At least 10 minutes. Good luck with that...on a seperate not my in-laws live in Pleasant Grove. Nice area.
2 things to do.
Like a previous poster said run a bottle of Sea-Foam through it. The way I do it is like he said. Pull the hose off of the brake booster and then put about 1/2 a can in there while its running. Then cut the motor off. Let it sit for about 15-30 minutes. Start is up and let it run for a while, rev it up, drive it around whatever. Be prepared for ALOT of smoke. I try and do it in a fairly unpopulated area as not to arrouse concern from bystanders.
Also, don't know if they sell it where you live but here they have a can of stuff made by CRC called "Never fail" if I remember correctly. It is guranteed to pass emissions tests or your money back. I have never had to do it. My mothers 5.0 Explorer recently failed due to a "bad catalytic converter" and half a bottle of Sea-Foam in the intake and the other half in the gas tank and 30 miles of driving cleared it up.
Good luck.
D
When my '94 falied a couple of years ago, I ran the gas down pretty low and poured in a gallon of alcohol. Passed with flying colors. -Now I just register it in a county that doesn't have emissions checks.:rolleyes:
Just fine. It was a gasoline/alcohol mix. Probablly 1 gallon alcohol and 2-3 gallons gas.
Picked up a can of Seafoam. Gonna try it today, hope I don't piss off my neighbors...
I tested it shortly after I clocked in.
Here's the emissions report...
I know what's up with the HC's, so we won't go there. :D
It's the CO % that I'm worried about. Mainly the idle part...
If your car is running right, emissions shouldn't be a problem. High CO indicates too rich of a mixture. I'm not an expert, but a quick internet search (or a search of mud) showed some possible causes: O2 sensors, leaky injectors, ignition timing.
I assume the car has been tuned up fairly recently. You might try some simple things - tune up, clean the O2 sensor(s), and run some BG44K (or seafoam) to clean the injectors. The seafoam would have to be put in the tank rather than the PCV to clean the injectors.
Since you work at the shop, can you get it tested multiple times for free while you are troubleshooting? I'm not an emissions nazi - but sometimes it can tell you a lot about how your car is running. If something needs to be fixed, better to concentrate on what the car actually needs. But sometimes you got to stick it to the man - I understand.
Yeah I can test it multiple times... Just have to pay for the certificates themselves... Like a dollar a piece :cool: :steer:
I'm going to run some seafoam through the intake and see if that helps. Also gonna turn the AFM back to stock... :o
I read all sorts of 'tricks' on here so far to get it through testing...and yes some of them will help, but the fact is that with the mileage you have on your truck.. most likely your cats are probably done and need replacing. They just simply aren't burning off the excess fuel like they should.
The emissions testing in our area is tough with a full 4 minute dyno test and I have tried all the tricks with a certain amount of success....but if your catalytic converter is defective you won't get through no matter what.
btw...do you still have the cats on that truck?
Yup, original cats (to my knowledge).
All we have here is a two-speed test. 30 seconds at 2500 then 30 seconds at idle.
I turned down the AFM as well, the exhaust smelled like gas when I throttled it.
