Factory winch troubles
FRASER VALLEY,BC
I have a 80 with a factory winch, and cant get the clutch lever to engage. There is a cap that is threaded onto the lever and is chained to a ring. I asked myself why they would go through the trouble of making this cap removable and chaining it so it wouldn't get lost. I came to the conclusion that there probably is supposed to be a bar or something the attaches to the lever to increase leverage for engaging the winch. Who else has a factory winch? Do you have a bar or something similar that came with your truck? Also I dont have the bar for getting down the spare tire. Anyone have any ingenious methods of getting it down, or know were I can get a new one?
You might look down at the bottom of the compartment in the DS rear where the jack is stored. I'm talking under the jack where you can't see, you actually have to feel down there. After owning my 80 for almost 9 years, I was in there for something and dropped part of the jack handle down there. In addition to the handle I pulled out some Toyota tools that I thought were lost by the PO. If you bought yours used, PO might have just thrown stuff in there in a hurry and just not got around to cleaning it out before selling it. Sorry, I can't help with the factory winch. - HTH
Push it in, then turn
Your talking about the compartments on the sides of the rear cargo area? because theres nothing in them at all. no jack or anything.
Yup. You have an electric and you are trying to mover the lever to free spool, correct?
Push down on the shaft that enters the winch body as you move the lever with the silly cap and chain. There should be some marks on the winch case that corespond with the lock detents.
Oh ya.. and if it feels like it doesn't want to go, move the spool a bit to get the gears to mesh.
Nice Fire truck BTW
Yes. The one on US DS in my '94 is for the jack (two 1/4 turn locking latches on L-shaped compartment door). The compartment is deeper than it first appears. It may take a flashlight or mirror to see or a small hand to feel around the bottom (9 - 12 inches below luggage compartment floor). Since you say youurs is empty, you don't have to pull the jack out. 3 bolts will remove the plastic bracket and rubber strap that held the jack. With the bracket removed you should be able to see more clearly to the bottom. Anyway, that is where the jack and spare removal rod parts were stored. You may even find the whole tool kit fell down in there if you're lucky. Also that compartment extends to the front side of the wheel well (I know, because that is where I store my jumper cables) behind the luggage compartment wall. You can see the fuel filler door release cable attached to the out side wall. If you don't find anything, at least you found a new place to stock spare parts or whatever in your Cruiser.
I just looked down there and there is WATER in the bottom!!!!!!!! AHHH no tools or anything. Im going to pull off the jack holder and clean it out. How the hell would water get in there?????
There's some drain tubes that go through there and I believe there's a drain plug (access from under rig) that you can pop out also. You might be getting water from the rear window channel above the compartment. Sorry you didn't find the tool/jack kit or anything useful. You might be able to fab a rod to let your spare down. Might even try an auto recycle yard. There's plenty of other vehicles that used that type of spare holder. I've seen fold up rods and segment (fishing pole) types. Might even be able to get a usable jack, too. One other resource is MUD classified. Just found a thread for you r leak: https://forum.ih8mud.com/80-series-tech/250940-water-leak.html
Got mine on EBay shortly after I purchased the truck along with an alarm fob. IIRC the jack and tools sold for about $40.
There is a piece of trim beneath each rear window. There is holes in the body that the trims
plug into. The little sponge seals dry out and disintegrate. Generally when you get water in the rear quarters that is where it comes in.
Do a search and you will find some tips on sealing it up.
