Factory trailer harness part #
Does anyone know the toyota part number for the factory trailer light wiring harness that will plug into the factory harness for a 97 landcruiser?
Geologic
97LX
10LX
07LC
I used the Hopkins #43405 harness on my '97 with no problems recently. It provides the flat 4-pin hook-up for the trailer.
The factory harness is expensive - close to $200 I think. The Hoppy or the Drawtite seem to be the most popular and can be bought for less than $30. The Drawtite connects from the outside of the truck behind the spare tire and the Hoppy connects behind the US passenger side rear panel and then needs to be routed outside the truck from there. I have had no problems with the Drawtite and the install is simple.
I never heard of "factory" trailer wiring harness but apparently there was one...
I also use the Hoppy harness plugged into a Hoppy adapter that accepts both the 4-pin flat and 7-pin round. True plug and play for the '93 and up 80's. The base unit goes in the PS rear wheel well and one connector attaches there and you run the other connector across the rear under the carpet to the DS rear wheel well. The hardest part of the install is getting the trailer connector outside of the truck. I ran mine out through the PS wheel well grommet. If you only occassionally tow then you could run it out under the hatch while towind and then tuck it inside when done. If you tow a lot then maybe the Drawtite solution might appeal more to you.
I use to have one of those aftermarket "powered" light harnesses (Modulite or something installed by the PO) that I tore out. It was NOT plug and play (spliced into the tail light wires) and didn't work worth squat (couldn't get the running lights to come on). Yanked it out, put in the Hoppy, and voila. My camper has probably 10+ running lights besides the brake lights/turn signals yet the LX doesn't seem to have any problems powering the trailer lights.
I have Hoppy, took about 15min to install, works like its supposed to.
Dealer told me the part was no longer avialable. seems hard to believe, thinking they would be somewhat universal to several different years/vehicles.
Maybe CruiserDan will chime in here and tell us if the factory plug and the several feet of wire that goes into the cargo area is still available?
The "factory" unit was port or dealer installed . Most likely scotch locked in(soldered or shrink boot not happening), wires run under the carpet/rear inside sill plate (seen a few pinched and after a while of time the SS sill plate rubbed through the wires an shorted out ) not a plug and play unit .
It was a turd , nothing more then a universal trailer light converter you can get at any Walmart .
The drawtite and hoppy units are much nicer then the one you got at the dealer
