factory sub replacement
Abbotsford B.C.
I like many other 80 series owners have wanted to replace the factory sub with a "sub" but have not found anything in the 6" size. While cruizing a local flee market last week i came across an old self powered 100w bazzoka tube, and figured for the 20bux the guy wanted id try it out. The results were nearly bolt in, with a new power wire from the battery run to the back i bolted the bazzoka amp to the factory sub plate and tied it into the speakerlines in the back and wala! i dont pound down the road but i was able to turn the bass down on the deck and have well rounded full sound with no distortion in the upper volume ranges.
Hope these pics help someone as it was one of those easy upgrades i wish i had done years ago:cheers:
Im curious as well. I have stock bazzoka from my '04 Scion sitting in the garage, perhaps I will try and use it in my LC. :)
factory sub
sorry i didnt take more pics. I did try to post a couple more i have but i dont know how to compress them yet as i am a new owner of a MAC. The Bazzoka tube was a standard old school tube with its own puwered amp.... 100w i am sure. I just took the sub out of the tube and the amp. The sub fit the hole in the factory bracket like a glove only catch was the holes didnt line up so i poped some new ones. I took the factory toyota (panasonic) amp off the sub bracket and mounted the bakoka one by drilling a couple holes in the aluminum heat sink. Then i got out the old trusty FSM for the pin code on the toyota harness. Picked up the speaker in lines and put them into the high level in on the bazzoka amp, also i used the factory switched power to excite the amp and ran a new 10 gauge power and ground up to my factory ACC fuse box under the hood , as the factory 16 gauge power wire was not attiquit ( and sorry FJ owners i dont think you have the factory ACC fuse box under the hood. Ill try to post a pic or two now and ill take the pannel off next weekend and snap a couple to post finished product pics.
I have two "old school" Bazooka tubes. One is self powered and the other is a slave tube that hooks directly to the powered one. There is a crossover control on the back of the powered tube. I've been transferring them from vehicle to vehicle since I got them.
Your install is nice. But you would have achieved better sound if you left the subs in the tubes as they are designed that way. I realize that they take up space. I always install mine for easy removal - just unclip the harness, loosen the tie-down straps, and remove.
I have yet to install them in my HDJ81. I'm going to build them in to the storage drawer system I'm currently planning. I've always found that running the tubes in a front to back orientation, with speakers facing back gives the best sound. So I plan on building them into the drawer system on the sides, to the outside of the two drawers.
Stay tuned for more details...
BTW: Good find on the old Bazooka tube. They were available in 6", 8" and 10" powered or slave. I bought mine around 1990 and they still perform flawlessly.
Did you run new wire for power etc? or did you re-utilize some already in the back of the truck?
