Factory speakers suck.....
Deep East Texas
Installed my Pioneers this morning. Piece of cake.
Haven't got around to installing the new HU yet....and I didn't disable any of the other speakers today. But, right away you can tell a big difference.
The remaining factory speakers only serve to "muddy up" the sound of the new ones...so disconnecting them is the next thing on my list.
You don't realize how truly "piss poor" the OEM speakers are until you replace them. The Pioneers are far from "top of line", but they walk all over the factory offering. I actually think a pair of "Dixie Cups" on a string would be better than the factory speakers.
Rear speakers took me longer than the fronts, but I got them all changed out in just over two hours. My fronts only needed to be spaced out about 3/16" so there was no noticeable bulge in the door panel.
Be certain to tighten all the little screws on the back side of the front door panels, several of mine were pretty loose.
Which model speakers did you install?
I remember replacing my fronts with a set of Kenwoods, that made a HUGE difference.
Pioneer TS-G1641
Pioneer TS-G1041
I cut the back out of the (rear door) factory mounting cups, bent 3 of the tabs on the new speaker over the outside of M/C and pop riveted in place (removed 4th tab).
Fronts were spaced out using self sticking hard felt cushions from "Lowe's" and longer mounting screws. Very quick and easy.
That right there is ingenious. I did that with my rear doors as well... In fact, we used the same rear speakers.
It works really well...but I must tell you I can not take credit for the idea. One of our other forum members used the factory mounting cup in a similar fashion and I thought it was a great idea.
Originally...I was going to put 5-1/4" speakers back there but couldn't get a defining answer as to whether or not they would fit before it was time for me to order.
Anyway, the 4" sound just fine to my (non-audiophile) ears, so I am happy.:)
Same here. Then I ended up going with some Infinity 4" speakers, but the magnet was too damn big to fit... :bang: So I went with Pioneer.
I have a 92 fj80 and I have delayed replacing the speakers because I assumed that it was an amplified system and needed all new wires run. Is this the case? What kinda of head units are you guys using, double din or single and a pocket?
It is an amplified system, but the amp can be easily bypassed with an aftermarket harness.
You can use either single DIN or double DIN units, they both fit. Most, though, use single DIN units with the pocket underneath.
More info here: FAQ - Radio Installations
