factory roof rack differences
Yes. I know this is an old thread.
But I can't seem to find the info anywhere on MUD, so...
Based on reviewing A LOT of photos online, I believe these are different OEM / Factory Roof Rack configurations for both 100 Series Land Cruisers and Lexus LX470s.
This should help someone buying a Factory Rack off eBay, Craigslist, etc.
Land Cruiser
1998 – 2000 shows 6 supports (3 per side)
  • Front support is above the rear of the front door
  • Middle support is above the rear of the rear door
  • Rear support is above the rear of the rear side window
2001 – 2002 shows 4 supports (2 per side)
2003 – 2007 shows 6 supports (3 per side)
  • Note: Appears to be the same configuration of the Land Cruiser from 1998 to 2000
LX470
1998 shows 6 supports (3 per side)
1999 – 2002 shows 4 supports (2 per side)
  • Front support is above the front of the rear door
  • Can’t find the Part Numbers for the Side Rails
2003 – 2007 shows 4 supports (2 per side)
  • Note: Appears to be the same configuration of the LX470 from 1999 to 2002, but at least some of the part numbers are different
  • Part Numbers for the Side Rails show 2003 – 2007
LX470
Some additional observations I've made for the LX, please correct me if I'm wrong:
1998:
  • Not every 1998 came with a roof rack (press photo)
  • Roof rack is matte black
1999-2002:
2003-2007:
  • Roof rack is paint matched to the body (glossy)
  • Side rails are different than 1999-2002 models (the end pieces/attachment points are slightly different)
Here's a picture of my 1999 (close) next to a 2004 (far) - my 99's rack is matte black and appears to be slightly taller, while the 04's rack is glossy white and appears to be slightly shorter.
Are the crossbars the same on LC & LX and interchangeable?
Hmm, well my 2001 LX has body coloured roof rack and crossbar, just to muddy the waters 😁
1998:
1999-2002:
2003-2007:
Very muddy waters. Might also be a Canadian vs US market thing. I'm jealous of your headlight nozzles.
This is a 2002 with a body matched rear deflector (haven't seen that before) and unpainted OE roof rack.
This is a 2000 with a body matched OE roof rack.
I don't think anyone was paying up to paint their roof rack so I feel like it has to be a distributor/port option.
Hello Blake1,
It's my understanding that all 100 Series (both Land Cruiser and LX470) have 4 sets of 2 mounting holes on each side.
But no factory / OEM rack uses more than 3 sets of 2 mounting holes per side.
So, if you buy a complete factory / OEM rack off of any LC or LX470 and replace the entire rack, it should work.
Note: Your LC / LX470 may have a trim strip (painted aluminum I do believe...) on each side of the roof that has 2 or 3 rectangular openings per side where your original roof rack mounting points were.
If your "new" replacement rack has different mounting points than your original rack, you'll need to remove this trim strip.
IMO, it's better to not install this trim strip.
It traps water / salt / dirt which can lead to corrosion.
Enjoy.
Tom
