Factory FR/RR differential locks not engaging
I recently purchased a 1994 fzj80 with factory lockers. Every time i switch the differential lock knob (after locking the center differential of course) I see the differential lock indicator lights flashing in the dash, indicating that they are not engaging. Does anybody know what could be the probable causes for the differentials not engaging and how can it be corrected? I'd appreciate any information anyone can provide me regarding this.
First thing to get your head around is how these things actuallly lock.
Basically you have a dog collar at the differential end of on of the axles, it has teeth on the diff side that mate with the a set of teeth on the diff itself. When they mate they lock the axle. If the diff and the axle are moving at the same RPM they will never change their position relative to one another. Hence you must create a differentional. This is commonly donE buy driving the vehicle slowly in a wide arch. This will create the necessary difference in RPM between the axle and the diff and allow the teeth to mate. :popcorn:
That's right, maybe more simply stated, one wheel on each axle has to turn about 1/5 of a revolution farther than the other in order to get the lock to engage on that axle.
This is easily accomplished by turning in a wide arc as Cruiser804 stated. The front is likely to lock up before the back, as this is more easily accomplished up front, but the back should follow rather quickly.
Sitting still, or driving straight with no wheel spin it is likely to never lock up.
I'm going to try doing this either today, or tomorrow and see how it goes. Hopefully it will do the trick. I must say, you guys are all amazing! This forum is fantastic! I am new to the fzj80 and in reality don't even know much about vehicle mechanics in the first place, but I love to learn and I don't think there's no better place to learn about this, than here because you find so many well informed and experienced people eager to lend a helping hand. I am really happy I have come across this forum. I'll come back again and let you know if it fixes the problem.. Thanks a lot
Just make sure you do your testing on dirt or gravle, not dry pavement.
It really doesn't matter where you do it, but it will be more difficult to get them to unlock on pavement. They can be tricky to get to lock when you don’t need them, but if the actuators are working correctly they will lock when you need them, wheel spin makes them lock right up.:D
Working Rear Differential
Well, I finally took my cruiser out in the sand and played with it for a little bit. After purposely getting stuck in the lose sand I shifted the lever to engage the cdl, which engaged imediately (as it always does). I turned the front/rear differential lock knob and started driving the vehicle in a wide turn and in just a matter of seconds I got a non-blinking rear differential light indicator on the dash. I unsuccessfully tried and tried and then tried yet once again to get the front differential to engage. Regardless of the fact that the front differential never did engage, I am still hopeful that all it needs is a little exercise as the previous owner seldom used this feature if ever at all. Thanks all for the advice
