factory e-locker questions???
AUSTRALIA
G,day everyone, I currently own un unlocked HDJ80 and im looking at buying a pair of factory electric lockers our of a sahara. What im wondering is will they fit strait in or what has to be done so they will? Iv'e heard the axels are different but im yet to confirm that. Also how strong are the lockers, can the hndle much abuse? I will be running 38's. cheers
With a tire that big, I wouldn't choose the factory locker. I would step up to something a little stronger.
There might be some debate that factory e-lockers would work for you, but it's a moot point if the axles aren't a direct swap. x3 on the ARB's.
Maybe its not such a great idea then, the main reasons I wanted the factory e-lockers were becasue they were $1000 AUS cheaper than new ARB's but in saying that the elockers were second hand.
e locker retrofit
There are many posts on this topic.
https://forum.ih8mud.com/80-series-tech/26446-retro-fit-locking-diff-non-locked-housing.html
Baja Overland
Slee - Retrofitting Lockers (Toyota 80 Series Land Cruiser)
I did it last month on my 92 JDM truck; bought a used e-locker with an extra actuator for $130 :bounce:.
A locked axle swap would be the easiest.
However don't be intimidated by a retrofit it is not difficult.
It took me about 4 hours to do my front end in my parking lot with the axle still on the truck.
Luckily on JDM 80 all the wiring is plug and play!!!!!!
I guess one day I should do a write up.
BTW The rear I swaped with an e-locked axle.
Cheers,
LandCrusher80
