Factory bumper tire swing out build, double shear hinge
Idaho
I made this tire swing out to keep the factory bumper and covers. I took a bit of a different path using a double shear hinge after getting spooked about the spindle breaking stories. 1/4" plate is bolted to the frame all the tubing is 3/16" except for the diagonals which are 1/8" . The hitch is all 1/4" plate except for where the latch attaches which is 1/8" and 3/16". The hitch took a few hits and drags (sounded like a distraught dinosaur) during the trip to Canyonlands last week but was undamaged, so that was a relief. Where the spring lock pin goes in is tapered to be self locking upon opening.
The rear view is off a bit, it does not stick out past the side of the vehicle.
Looks good. I really wanna do this!
If you don't mind, how much time do you have in the design?
Also, roundabout figure on $$
Thanks
Roughly, from memory.
Steel about $45 (some 1/8" I had laying around, not included)
Weld on lock pin $20
Latch $45
Lug nuts and studs (autozone) $10
Double shear hinge kit $45
polpro/plastic pads - free
Paint $15
So budget planning about $200
Time in the design, way too much. Started looking at the build threads here then adapted for the double shear hinge. When I had the concept I started building, it was a design as I built project. Head scratching along the way type of project.
Nice job! I've been looking for this option myself - can't shell out the $$ for a full bumper anytime soon and don't like the spare in the cabin. Any thoughts on build to sell?
There no such thing as too many pictures, I wouldn't mind seeing a few more of different angles. Was there a particular build thread you thought was better than others? You obviously have good fab skills, so why not do the entire bumper?
... You obviously have good fab skills, so why not do the entire bumper?
Thanks, but you didn't see the mistakes, haha
I didn't do the the whole bumper mainly to save weight. I do drag the plastic bumper at times but it is holding up so far.
Here are a few more pics. If you want to see something else, let me know.
Locking plate
Mounted on the frame from the side and below with 1/4" plate. There is a 3/16" backing plate inside the frame box on the side acting as a big washer. I did not want to weld to the frame.
On the Canyonlands trip I think it would have been more challenging having the tire underneath in a couple of places, snow up high and rocks in the last picture.
Drift busting, backing up for another run at it. A lot deeper than it looks. At least the deep snow was washing off some mud!
Another inch of tire height and I would have made it, it was that close ;)
I had to winch off.
