Factory analog radio help
I have a 1980 toyota truck with the analog radio. I need help, if someone can teach me how to set the presets on it. Also the preset buttons are sticky, how would one clean or lube the buttons. What is safe to clean or lube electronics?
Can't help w/cleaning, but if the pre-sets are like the ones I'm use to:
A) Grab a single button with your thumb and forefinger
B) Move the button right or left while pulling towards yourself...should pop out a bit
C) Set the dial where you want, then push in to lock your setting
And cleaning the sticky stuff, I would think Electrical spray and a rag would work...maybe a Q-Tip
Thanks, John
Thank you john, the wiggle you suggested is the answer, worked just as you wrote. i willsearch for some spray. Thanks again
