missipboy said:
just left napa and the napa guy called a friend of his who is supposed to specialize in a/c. don't know what "specialize" means, but he said that there was another switch under the hood that makes the compressor cycle on and off so as to not freeze up. if this is true than i can put the clutch and fan on toggles and it will be ok. what do you guys think?
On mine ('80 witn ND air) there's a pressure switch under the hood. It's about 1 foot in front of the firewall where the AC hoses go through. If you start at the firewall and work your way forward you'll run into it. It will stop the compressor from running if it's bad. If that switch is working properly and stopping the compressor from running, bypassing it would be a bad thing.
I'd spend some time with a test light before hacking on it too much. You can put a probe at the controller wiring to see whether compressor power is coming out of the box. If it is, the problem is further out under the dash or the hood. If it isn't, either the unit's bad, it's not getting power, or the wire from the coil to the emissions computer is off. The AC controller is tied into this wire. Mine doesn't turn on at idle (I don't think they got the idle kick up for AC until 81?) but once you get some RPMs the compressor will engage.
Then just follow the compressor wire and make sure it's getting 12 volts all the way to the compressor. If the control unit is bad, you can definitely wire the clutch to a separate switch. When I got mine it was wired up like that.
If you decide to pull off your controller and sell it I'd love to buy it. I need the knobs...
Edit: The biggest problem with manually switching the compressor I found was that you have to run your idle way high to keep it from dying at stop lights when the air is on. When it's off, the idle's too high. This one has a Holly, so even if it ever had idle compensation it's long gone now.
Also, did you check the AC fuse? I believe it's taped to the harness right by the ammeter fuses in the engine compartment.
