F or 2F
Okay, thanks, I can see it below the Fram oil Filter. That is something I can't get down here, Purolator oil filters. Years ago a bunch of us racer guys bandsawed through all the major oil filters and Purolator and Wix are the best. Fram makes about everybody's else's filters and they are really the bottom of the barrel in my opinion. But, I see the sensor, looks like the wire was cutoff.
It's directly under the "P" on your oil filter. It's a post, the cut wire is off the previous trucks writing harness.
It looks like you have both the temp sender and the oil press sender.
Are you installing this motor yourself?
No, I do not have the equipment or facility to do that down here, drat. So I have a mechanic who does general repair work as well as ground up restorations on Range Rovers, Land Cruisers, Jeeps and old Broncos. He will pull and install this engine. What I want to make sure of before I take The Beast over is that I have everything on hand needed to do the job so that it doesn't sit in the shop, out of use, while I await parts from the USA. Something like that.
