F or 2F Engine...
Website
www.geocities.com
Hello, i am fairly new to the Landbruiser world, i have purchased my first FJ40 and am getting it all wire-wheeled (wish i owned a sand blasting gun) to paint. However, i am looking into doing some engine work before i put it all back together. I was wondering how i tell if it is the F or 2F engine. It's a 1970 FJ40, so i imagine that it is an F engine.
If someone could help me figure this out that would be great!
Thanks...
Here's some info on engine ID from JimC that I saved . I think the F numbers are in the same location. Not sure though.
The date code is cast in the block on the manifold side, midway between the last two core plugs.
It is a 5 digit number.
First digit is the year.
Next two digits are the month.
Last two digits are the day of the month.
So your block might have a number like 91217
9= 1979
12= December
17= the 17th
Well I have a 68 with an f engine in it and it runs fine. If it doesn't need rebuilding don't worry about it. Drive it around for a few months then make your decision if you're gonna switch to a 2f. Where are you located? Welcome
The easiest way to tell if it is an F or 2F is to look just behind the distributor, there is a stamp there that starts as F or 2F. I actually just asked this question that's how I know the answer.
Happy Huntin.
Is the engine already out of the cruiser? If it's in place and runs decent maybe with some tuning I'd leave it til it was about dead. Also depends on what you use your cruiser for...A daily driver I'd prefer the 2f. Mine is an occasional use, nothing hardcore, mostly hunting rig. the f has been dependable enough for me so far....but I have a 2f sitting and ready when it's no longer dependable.
iam_turner said:
Thanks for the rapid (previous) reply...
What are the advantages of a 2F (aside from it being newer) would it be worth rebuilding the F-engine, or would I be better off to invest in a 2F?
Thanks.
2F is bigger capacity - 4200 vs 3800 for the F
2F has better lucrication system, bigger oil pump.
When you need to rebuild, do a 2F - until then keep the F
F series (inline 6, 3.9-4.3L, cast iron head, 1948-1992)
cc hp@rrpm torque@rpm
F OHV 2 48-75 3878 135@3800 217@2000 89
2F OHV 2 75-87 4230 135@3600 210@1800 94
2F OHV 2 82 4230* 140@3600 218@1800 94
3F OHV 2 85-90+ 3956 144@4200 203@3000 94
3F-E OHV 2 88-92 3956 155@4000 220@3000 94
This is taken from a link in the technical links section (above)....difference between an F and 2F is nothing worth getting excited about. Mant people are all googley eyed over the 2F...never understood this. True a better designed oiling system in the 2F....but again IMHO not worth getting all wet over it. My 73 has iit's original F in it....runs great especially with the electronic ign system out of an 85 :bounce: Plus you don't have the smog crap to deal with...
My 71 PIG has 73 F engine and 3 on tree. Had bottom end redone 5,000 niles ago then I spun a rod bearing, fixed that and the engine runs like a top. Only issues I am having is with the carb.
I agree with all others on leaving the F until problems arise. Toyota has discontinued a lot of parts for the F engine but most NAPA's and CarQuest parts stores should be able to get parts.
I will do a 2F swap when the F lets me know its time.
my .02
Chuck
Aweseom! Very helpful...
I'm sure it's an F - looked the other day and the F stamp was sure to be seen.
The engine is in the truck, but i don't have the cruiser on the road yet - still grinding the old paint off, i hope to be finished all the body work by next weekend, maybe I'll be able to put the first layer of paint on. I'm getting excited!
Can't wait to drive it out of the garage.
