Ok guys, I'm a newbie to the cruiser world, however I've built my share of big and small block 4wd Chevrolet trucks. I rescued my cruiser from a 12 year stint in an old man's basement. Here's a list of what I've done to a completely stock cruiser.
71 FJ40
Weber 38/38
Header
DUI (not me, the dist.)
GM 108Amp Alt.
G-able pins and bushings
New stock length shackles
Lock-Rite rear
Rebuilt master/booster
Rebuilt Clutch Master/ slave
Disc brakes front and rear - JTO (more gm parts
Front and rear bumpers
Family Cage
16" steel wheels
265-75-16 mud tires
The truck runs great as long as it's 50 degree out and I let it warm up.
With this list of mods should it take 20 minutes for the engine to warm up enough to run above idle? I know that with the header I lost the factory heat exchanger on the exhaust manifold. The engine will tend to backfire as if it's too far advanced until you can coax five miles or so out of it. Also if it's colder than 30 degrees (F) outside without a cardboard radiator she won't make it out of the driveway.
Should I try a clamp on heat exchanger from a header tube to my stock airbox?
I've got timing set at 8* BTDC per the sticker on the truck. Will the dist, or the weber change this?
I've really enjoyed this crash course into the metric system.
Any help will be most appreciated.
I'll try to attach some pics in a few...
71 FJ40
Weber 38/38
Header
GM 108Amp Alt.
Lock-Rite rear
Family Cage
16" steel wheels
265-75-16 mud tires
