F engine won't stay in time?
Hello
I am working on a cabin that is over 200 years old, I'm talking with the owner and LandCruiser come up. I used to restore FJ60's, he says "really, I have two 40's here, one's a junker the other I can't get to stay in time. I can set the timing and then it goes out of time." This guy is an amazing mechanic, he rebuilds giant diesel engines for a living. So why can't this guy get it stay in time? He thinks it is the timing chain, but I think there are just timing gears. He doesn't do the internet, so let the opinions fly, I will be printing this for him. The reason I ask is that I am just familiar with the 2F and don't know how points could effect this?
Thanks in advance.
ERICH
Distributor bushing/s are shot....or the gear is no longer tight on the distributor shaft where it meets the camshaft....
Remove the cap and rotor....and you will be able to wiggle the distributor shaft around in the distributor I would bet....
It would also help to know what year we are talking about, whether it is one of the earlier points dizzies, or one of the electronic ones.
I have also come across a phenomenon 3 times now in the last year of people replacing the points retaining screws with new screws that are just a little bit longer. Long enough to hit the plate underneath the top plate. On two of them, it made timing advance inconsistent, as the screw was just long enough to put a drag on the lower plate. On the third, it stopped the advancer all together!:eek:
Hth
Mark A.
I forgot to mention that he said he thought it was a 68', it is his son's and was trying to getit running well for him.
Thanks
ERICH
No suggestions of a cure but I have a somewhat relavent question.
Do the F and 2F engines have a harmonic balancer?
I had a 66 Chevy truck with straight six (almost identicle to the F series engines). On that rig the rubber in the harmonic balancer deteroriated to the point you couldn't set the timing with a light, it had to be timed by ear.
X2 or if has timing chain it could be that also .... i have seen the timing chain thing happen.
Good luck.... :)
Must be a small block boys eh? ;)
The timing mark for a Land Cruiser F and 2F are on the flywheel....not the front balancer....
The cam is driven off the crank by gears, not a chain on these engines also.
:beer:
:beer:
I like straight six engines, I've only owned a couple of vehicles that had v-blocks.
:grinpimp:
We ain't got no stinking chains.
But for chains of love..........or chain of fools.
How far out of time?
A few degrees - I'd go with the points slipping or the dizzy bushings being worn.
A bunch, I'd check the roll pin that holds the dizzy gear in place. I've seen 'em break and let the gear rotate but still turn the distributer.
Pulling the dizzy will also give him the opportunity to check the condion of the drive gear teeth.
