Well, I'm frustrated at searching the internet, looking through supplier websites, and trying to search through mud, with no luck.
I'm looking for an “f” engine rocker shaft stand and clamp.
I installed Holley fuel injection on it and was trying to get the final relearn done on it, but it was loading up (because of to much fuel pressure with hollys built in pressure regulator, another story on that) and I had a bad backfire.
I determined the cylinder that is missing then removed the valve cover and found my reason for the cylinder miss and of all things a valve rocker lifter shaft became unconstrained by the the rocker arm receptacle. Pushrod is not bent, or damaged, it just came loose from the rocker arm. Why bad backfire?!?!
So, I'm investigating and see that the rocker arm shaft stand cap corresponding to that push rod is cracked down the centerline of the cap , nothing is distorted, (I recall seeing the crack a long time ago, but it was not running in the shop and I wasn't concerned with that then.
Well now she's running and I need to replace this cracked stand and clamp at minimum.
So does anyone have a stand and clamp they want to sell? or should I buy a whole set of the stands for integrity of like parts etc.
What I have is a "F" engine, 1966 model super low mileage, runs like a sewing machine before the backfire and part disconnection issue.
