F engine backfire
Behind the zion curtain, Utah
Ok Brethren...
I have searched high and low for answers, I have a 71fj40, sotck except for headers and a $%#%#%#Weber progressive carb, I just had a new exhaust installed and now the backfire out the exhaust and occasional one up through the carb is really annoying/distribing.
so once again I come looking for help....
I have adjusted the valves...twice according to Jim Chenoweth's instructions found here on the forum.
I have tried several different timing spots and am now at my wits end.
When I set the timing to fsm specs it backfires through the carb under acceleration and out the exhaust at idle.
The stock carb came in a box,
I'm open to any ideas at this point.
oh yeah I have also changed the plugs/cap points ect.
the motor was rebuilt by the PO and has allways had this problem,
Soo...
is #1 on the dizzy next to the motor? or should it be closer to the fender?
can I get the stock carb to work well with the headers?
What Petronix module will replace the points?
is a 3fe head and fuel injection an option?
Thanks
I finally set the timing so I can step on the gas with out too much back fire but when I let off the gas it pops out the exhaust
ARRGGGGHHHHH:censor: :censor:
If your sure everything is correct that you have done so far.... check the cam to crank timing... I've had some cam gears ( stock toyota ones) slip... they have a rubber damper built into them that plays-out after years of use....
The only self dought I have is in regards to the spinning of the motor 360deg during the valve adjustment... motor was at TDC mark with the #1 piston at the top when I adjusted valves #1,2,3,5,7,9 then I spun it till I saw the TDC mark again but the rotor pointed to # 6 when I adjusted valves #4,6,8,10,11,12. There for the rotor went 180 deg and the crank went 360 right?
An easy way to get to #1 compression stroke... remove #1 plug.. put your finger over the hole & bar the engine over until a push is felt.. complete rotation until timing marks are aligned... if you have the valve cover off? # 1 cyl. valves will be closed & cyl #2 exhaust valve will be at the total open stroke.. rotate crank 1 rev. & #6 should be at top dead center # 5 exhaust valve full open stroke... to check timing on crank to cam.. you need a dial indicator & some help........Are you running any smog control stuff???
yep, only I used a screwdriver after I was at tdc with # 1 to check if the piston was indeed up.
I took it to the store yesterday and noticed that the tach was bouncing at idle..about 300 rpm, a local ford guru thinks its a bad dizzy?
I have a dial indicator that I used for checking end play on aircooled VW flywheels..
no smog stuff the rig came from Grand Junction Co ...no inspection or smog there.
Check it out using a vacuum gauge..... mans oldest friend
You could have a bad dizzy. Use the dial indicator to check the side to side play of the shaft with the rotor button off. Should be .002 run out. Or a quicker test, if you can wiggle the shaft side to side, the top bearing is worn out.
