F Carb Rebuild??
Western Slope, CO
I rebuilt the carb on my 74. It was running fair but the carb was wet all the time and I was concerned about starting a fire under the hood. So I have the stock air intake and when I started to pull things apart noticed what seemed to be a fair amount of oil/gas? in the filter canister. Is this normal? I have replaced the gaskets and still seems to be leaking from the top of the carb where the intake attaches. The intake does not seem to fit properly on top of the carb. Does anyone make an aftermarket kit for this? Snorkel?
carb kit
Welcome-
I would get the toyota rebuild kit. If that carb is stock Aisin I would just rebuild it or have it done. there are a couple experts on this board. Try Jim C. or Mark's Offroad in the search button. Both of those guys do carbs as of the last time I checked.
The snorkel idea is very well documented within the search button option.
you can also use google and search "Royal Rose FJ55 cummins snorkel"
This guy in Utah make a nice snorkel for his FJ55. I am thinking about making the same one.
The air filter is an oil bath type. Nice filter, but it should have oil in it; not gas. Are you sure the carb leaking gas? Maybe the filter has too much oil in it. If it is leaking gas, the sealing surface on the carb top cover may be warped or dinged. You can true it up by sanding it on a flat plate of glass.
This is how bad it's leaking I had the carb rebuilt the week before the EJS in march. So how much oil should the filter have in the canister? Has anyone gotten away from this set up? would like a Webber but don't have the cash to spend on that right now.
Hey Pin... I have a '72 with the original "F" and my air filter isn't an oil bath filter. It uses a regular -- rather large -- round paper filter like the FJ62.
Do you have any other info on this? I'm curious now...
Jody.
Yeah Outback I'm sure that's what I have too it just thinks its an oil bath type. seems to be leaking from the top where it connects to the air intake
The reason the air cleaner doesn't fit is because the carb is not an Aisan. :crybaby:
The reason the carb is a leaky POS is cause it's not an Aisan. :doh:
If it's a 'murrikan carb, one of the sporty chrome air filters from your FLAPS would prolly fit. :grinpimp:
HTH
Yep, give Jim C. a call and get yourself an AISIN carb and be done with it. fj40jim@aol.com if I remember correctly...
Jim, the "F" carb rebuild you did for me a few years ago is still going strong. Love OEM Toyota stuff.
Jody.
