Extremely difficult shifting into low
Truckee, Tahoe, CA
I did the CDL and Pin7 mod yesterday and when I went out to test it. It took an unusual amount of effort to shift into low. I was forcing it and it finally engaged. In my last 80, it was easy switching from high to low. I am going to take apart the shifter assembly today, hopefully I don't have any transmission issues.
Any ideas?
It's only going from H-L. Its more than just stiff though.
Just thinking of the obvious, but are you putting your truck in Neutral? It is much more difficult to shift into low when in Drive or Reverse, and even Park can be difficult sometimes. I find I have no trouble when putting it into Neutral.
-Phil
You mean transfer case.
I would think checking the shifter assembly (as you say) should clear it up. Look for any crud impeding shifter travel, etc.
Oh, and you make it sound like this is the first time it's happened? Have you had this rig in low much?
Another oh: Might as well check the (T-case) fluid level.
Curtis
Question, have you shift the transmission to Neutral first, then try to shift the xfer to low?
Dang, Apple Tech beat me to it.
Problem solved, took apart the assembly, and there was a bunch of dirt/oil/crud blocking the slide thing. I scrubed it, sprayed some WD40 in there and now it shifts smoothly! Thanks!
What exactly did you take apart, is it accessable through the cab(transfer case shifter), or underneath cruiser where the transfer case is located?
