extraction point
73lndcrsr
I am looking to add a central extracton point on the back of my 40. I want a bolt on version of the attached. I would like to bolt it tot he stock mounting holes in the rear frame member. I am not currently running a rear bumper.
Anyone located something that will work?
. They make bolt on rings like that, but not that will match thre pattern om your rear cross memember.
Additionally, unless reinforced, the rear crossmember will deforme when subjected to heavy snatcxh strap recovery.
We reinforce the crossmember (usually with a 1/4 inch plate on the back and a 2x3/8 inch gusset on top of that) and install a pintle hook. This will bolt into the factory holes and is much more versitle than the d ring. A lot quicker and simpler to attach straps and other recovery 'connections" to.
Mark...
Also, you can get receiver ends that accept a recovery shackle.
The reciver bolts to the stock rear cross member and the recovery shackle can be removed when you're not using it.
These are sold by Man-a-fre
There were some bolt-on D rings on Ebay recently that would bolt directly to the stock rear center point of the FJ40. I looked but didn't see them today.
I'd recommend a Pintle Hitch...
attachment.php
Those bolt on receiver hitches that stick down below the crossmember... They will twist your crossmemebr like a pretzel under the stress of any sort of energetic recovery. I have had to repair several Cruiser that suffered that fate. :(
They're evil. ;)
Mark...
Thanks, I will look into the pintle.
I have already re-inforced the rear some and will add additional support for the bolts.
Mark...
Mark do you have any pics of your set-up?
Nice write-up on ACT 2006
Lane
I'm sure that I have some pictures around of one or more of our rigs with pintles on the rear. Most of us are running square tube reasr bumpers to additionally reinforce (extremely reinforce) the rear crossmember. But bumper or not, regular pictures won't show much beyond a rig w/pintle. Haven't taken any pictures up underneath the backside of the crossmember. ;)
I've heard that the new issue of the Trails is out. You folks in the Colorado area actually get yours even before I get my shipment from the printer! I have not seen the final product yet. :(
Mark...
I cropped two pictures with my pintle. You can see that in the first picture there are a total of 12 ea. 1/2in grade8 bolts 4 in the pintle and 4 on each side, through 3/16 in 3x4 square tube and the rear cross member. There are also 2 ea. 1/2in grade 8 bolts at each end to help make the bumper stiffer, this is for when I finally get off my A$% and build my spare tire/fuel can carrier pintle2.webp
pintle.webp.
Yep, Attaching the bumper to the ends of the crossmember is a requirement in my mind. Not just for tire carrier support An attachment to the lateral frame rails (usually through the tail light openings in the later model rigs) is even better for a bumper like this.
If you just attach it to the center of the cross member, you can (and will) still pull the whole bumper away and pucker the center of the cross memember.
Sleeving the bolts that pass through the outer face of the bumper is the way to go also. Makes the whole thing much stronger.
Mark...
I'm in New Hampshire and it came Monday! I've already told my wife that we "are doing the ACT when we retire" 8 more years!
Lane
Mark...
Hijack.! ;)
I got mine today after I wrote that.
A little disappointed. There were some great pictures which didn't get used in the article. Oh well.
If you want to see some of them, check this out.
http://www.xplorn.com/ACT2006/
That's not all of them, but there's some good stuff there.
Mark...
