Anyone have experience with AAAutowarranty? They say they will cover my cruiser's drive train even with 200k on the clock and all that for 3 years and $1300. Anyone think it is worth it?
but you do have to keep regular maintainance from a professional shop, so no home oil changes etc...
I've heard it's quite hard to actually get the payout on such programs.
I disagree. Warranty companies routinely provide warranty coverage on vehicles they KNOW they are likely to pay out on. All they do about it is adjust the premium accordingly. The more troublesome the car may be (eg a BMW w/ its ridiculous electronics), your premium will be pretty darn high. They'll figure EASILY over a grand a year in payout from 'em.They wouldn't be offering a warranty if they thought they'd actually have pay out on it. Bottom line.
It's highly warranty-specific. My warranty covers all internally lubricated parts, as well as gaskets & seals, AND covers "wear & tear" (minus specifically not included items such as manual clutch and brake pads & rotors). So if the engine is still running, but it's compression is below factory minimum specs, it's repair/replacement is covered. This happened w/ my RX-7. And I had them cover replacing the motor, even though it was still running - because one rotor was below the factory minimum spec. In another vehicle, the nav unit still worked, but one of the bulbs blew, so the screen was a bit dim (just not as bright as new). Still readable and 100% functional. But that's not within OEM specs, and the unit wasn't repairable. The warranty company paid for a new several thousand dollar OEM unit.Read the fine print. It will say something like "Failure of Internally lubricated engine components" are covered, this means things like pistons, crankshafts, camshafts, etc.
How often do these parts fail in a LandCruiser?
And, if you think that you'll get a free engine job when your 200K mile vehicle starts to smoke because the rings are toast, think again. They didn't "fail", they "wore out" and "worn out" components aren't covered.
Also, gaskets and seals aren't covered, so when (not if) your head gasket quits on you, get out your checkbook, and don't waste time with the warranty company.
Most of these warranties exclude a lot of the more expensive systems that DO fail, like electronics, ABS pumps and systems, etc. (these systems tend to fail a lot more on other brands besides toyota). So, read the details, and find out exactly what's covered and what's not.
My GFs extended warrenty works great! We just got a new 2.8l 24v VR6 in her '03 Jetta GLI... She learned the hard way why cold air intakes suck for a daily driver. Water doesn't compress like fuel/air mixture!
That would not be warrantiable failure from my experience (i.e., way too many years as a dealer service manager)...that would be insurance...as in State Farm sorta stuff.
That's why you keep the stock airbox lying around.![]()
Very nice you sly dog...well...then they are morons and deserve it...rods don't bend on air...they bend/break with water very easy to determine that that motor sucked water.
