Just completed trailer. 15 gallon onboard water with 12v pump and spray hose, optima battery wired to distribution box with accessory switches for water and fridge. Wired for solar charging. Full extension slide out for fridge and set up for folding partner stove. Brand new HIT JalamaCT roof top tent. Lifting cargo lid with gas strut assist. Timbren Axle less suspension with 4" lift spindles and electric brakes. 31" all terrains with matching spare. Steel structure with aluminum paneling and cargo box lining. Aluminum lid. Room for 2 propane bottles on tongue. Has pintle hitch for articulation but can be switched to standard ball hitch with 2 bolts. Asking $9,500
Purely symmetry for this one. I liked that the corners are pretty much in plane with the edge of the side boxes. They also give walls to the tie down areas to stack full of firewood or anything else you would want to load on the outside.
