was that an Autozone special 400 watter?I tried. Unfortunately, I used an inverter that could not handle the big starting surge. And it fried.
Not strictly accurate, inductive loads have a current spike at start up is a more accurate statement. Inductive loads include motors, such as the one in a fridge compressor.ac devices have a start-up spike draw...that 125 watts on start-up was likely close to 600...
yeah yeah yeah...Not strictly accurate, inductive loads have a current spike at start up is a more accurate statement. Inductive loads include motors, such as the one in a fridge compressor.
To be truly accurate pure inductive loads don't have a current spike as such, they have an exponential rise in current. But back to the fridge and what makes inverters smoke up. When an inductive load like a fridge motor is energized the initial high peak starting current observed is due to the low impedance the stalled motor presents to the supply and the absence of back emf - the voltage that is generated in the rotor that opposes the supply voltage and limits current. Back emf voltage opposes the supply voltage and the net effect is that instead of having say 120v across 10ohms impedance for 12 amps at some phase angle we would probably have something closer to 2, 3 maybe 5 volts across that same 10ohms impedance for a much much lower current.Not strictly accurate, inductive loads have a current spike at start up is a more accurate statement. Inductive loads include motors, such as the one in a fridge compressor.
Very good explanation.To be truly accurate pure inductive loads don't have a current spike as such, they have an exponential rise in current. But back to the fridge and what makes inverters smoke up. When an inductive load like a fridge motor is energized the initial high peak starting current observed is due to the low impedance the stalled motor presents to the supply and the absence of back emf - the voltage that is generated in the rotor that opposes the supply voltage and limits current. Back emf voltage opposes the supply voltage and the net effect is that instead of having say 120v across 10ohms impedance for 12 amps at some phase angle we would probably have something closer to 2, 3 maybe 5 volts across that same 10ohms impedance for a much much lower current.
nerds
