Expedition build home made
93 fzj with factory diff lock and 7 pin mod cdl switch and individual front and rear lock either hi or low
Nice build!! I like the panel on the hood. Cool use of Thule bars. That's something to think about for camping trips with it being easy to put on and take off.
Did you install the JDM carrier yourself?
Great setup and use of space
By the way it has a 220amp alternator to charge the triple batteries and two aux fan for the oil cooler and the a/c condenser
That's some nice looking truck, even before the gear is on! Hopefully you can provide more pics and details on some of those mods. I need all the ideas I can get. Like for instance the water tanks and how they are built.
Here's something I wouldn't leave home without...
A TV!
Is that live satellite, and if so what equipment do you use?
1427083313243-jpg.1049630
A TV!
there are two water tanks one is a 18 gallon which is located under were the spare tire used to be. the other one is on the top which a wrap around the roof rack made out of ABS pipe. the tank under you can buy it at a RV store and strap it with water heater straps. the mount of the tv is also the cabinet drawer.
Lots of good ideas, nice rig. Water tank in place of the spare is high on my list. Could you list the brand and model, fittings and if you have fill issues etc? This would complete water storage for my rig, have a FlexiTank in the passenger quarter panel. Thanks
forgot the brand but everything you would need to put this set up is at the RV place like camping world even the pump is the too but I got mine in Amazon.
really don't know the weight on it with water. But i know that the water is 2.2lbs per liter and there are 3.785 liters per gallon.
12 gallons would be right at 100 lbs.
