Some crappy exhaust shop did a shotty job for my 40's PO, and the exhaust hangs about 6" below the frame rail, and is routed beneath the factory skid plate. Can someone post a pic of how it should be, so I can fix this. I'm thinking it will clear above the skid plate, but am not sure how it is hung there below the driver's door.
IF it is a post-79 then it has to go outside the frame for the converter unless you have a real good exhaust guy.
We have been able to re-route them inside the frame and around the tank but it ain't easy and the pipe must be wrapped with heat tape.
If it is a pre 79 then it simply goes straight to the axle over the skid plate then muffler mounts sideways at the rear then tailpipe out the passenger side...
Butch
Sorry, it is a '78. Looks like it's routed correctly, just hung too low from the collector back. I'll prolly just cut a section from the collector back to the upward turn towards the axle.
Thanks for the help guys. I was pretty sure it would fit b/w the body and skid plate.
Funny this thread came up. Last night we laid out the exhauset pattern (on paper) for my truck. I'm using the dreaded over the frame headers from Advanced Adapters.
The plan is to have a 45 degree bend off the header running into a muffler all along the bottom rail of the frame. We're then going to route the exhaust (dual) towad the center of the truck to clear the rear brakes/axel housing and make multiple bend towards the bed. Eventually, the exhaust will exit at the rear with the tail pipes facing at each corner of the bed at a 45 degree angle exiting to the side.
I would suggest not running a side pipe exhaust at your doors becasue it will be noisy as hell (these trucks are already nosiy).
I would also suggest not running stright pipes toward your exiting stright at the rear door becasue the exhaust fumes will get you noxious. It's the little things that you have to consider when running exhause.
Do you have an SBC in there? Do your headers look like this?
If so, please start a thread on it with progress...I would really like to see how you accomplish this.
A buddy removed those in favor of stock cast manifolds, and has the system run to one pipe on the driver side, and out the back, all above the frame....
I guess if you are only looking to pound pavement, and do not mind the heat and the look, then those should work well.
Be careful if you are running it down the drivers side. I had mine done above the skid plate and everything was great until I needed to change my oil pan gasket ('77 2F). I slid under the truck to find all the oil pan bolts. I discovered that some of them were hidden under the clutch inspection cover. After unbolting the cover I realized that the exhaust pipe had it trapped in place. Needless to say, I've delayed changing the oil pan gasket.
My stock '75 40 has the exhaust running about 2 in. below the left frame beam. I'm sure it is original because the PO (neighbor) gave me a new muffler he hadn't yet installed. A while back, I saw an identical placement on a 40 in Portland.
i had those headers ,along time ago mounted the mufflers outside the framerails,below the floorboards
and then ran the tailpipe over the front spring hanger , through the leaf spring in front of the tire . and out the back .it worked but looked ugly when the mufflers rusted ,copied it from the
AA instruction manual
I also plan on changing these to anything that is better than what I've got now. I would also like to recommend these to anyone who wants to be loud and breathe in the exhaust, and catch the exhaust on a rock...did I mention that I did not choose to install these? PO did not plan on using it the way I do. And the result....
I had a design in my mind on the exhaust routing even before I got Rustydog's engine back in the bay.
I had heard and seen many cruisers with leaks when running headers. After speaking to a lot of individuals that had been doing this much longet than me I had formed an opinion on a possible cause and a preventive measure that would not cause any additional problems if it were installed.
If you compare a header to the stock manifold there is substantially more leverage applied to the joint were the manifold and block join. This IMHO is where we generate leaks with headers. Header flange is where the pressure is applied, on a manifold it is the flange where the exhaust attaches and the angles are substantially different.
I researched and located an all stainless flex pipe that is welded to the collector, then welded to the pipe. I also have a stainless muffler mounted in the same location as stock and then exits in the rear instead of the side. I also used stainless collector flanges to allow the removal of the front section of the exhaust from the front and the rear pulled backwards so that if I needed to remove it I could without involving the skid plate.
100% stainless from the collector flange at the header to the tip. It should outlast me.
Iron Pig Off Road did all the fabrication and TIG work to get the exhaust install completed. The skid plate is custom also and is a work of art itself.
heres a thread about my exhaust switched from dual to single .works great ,and you also have to turn your tail pipe out the side behind the tire ,not straight out the back or it will still stink . single exhaust sure cleans everything up
I do not have many of the full drive line but here are a couple of the underside.
Running the original F, rebuilt. 4 speed trans, 470.1 toy box, and 3 speed transfer case. Marlin rebuilt the 4 speed and the transfer case. He then assembled trans, toy box and transfer case and sent them as a unit to attach to the bell housing as an assembly. Running a disk brake front with Toyota E-Locker and a non USA full floater with a detroit.
