Exhaust modification ideas?
Longmont, CO
One more test and then no more testing..... Just wanted to know if anyone had any input on any mods for unrestricted exhaust regulation? Not trying to contribute to the smog or pollution - don't put a lot of miles on her so that's not why I'm asking - my cats are about to fall off and don't want to replace them if not needed. Thought was to cut them out and go straight back. Any O2 sensor issues? Anything else I can scrap that might help performance or at least un-choke her a bit if possible? Sorry, most of my exhaust experience is with classic American muscle cars but that was 20 years ago in another life
I completely understand the 20 years ago in another life statement!!!
i just did a straight thru exhaust and added a manual choke and pipes off a Ducati :
full open it breathes a bunch better on highway.....and restricted quiets it down and makes a bit more backpressure/power for around town / daily driver duties. So far im getting about 1.4mpg better around town........working on testing hwy mpg and fiddling around with throttle kickdown
Back pressure is a myth. Engines don't like back pressure at all.
Removing federally mandated emissions equipment is illegal and you'll face thousands in fines and possibly jail time if/ when caught (depending on the state). You will fail the visual and emissions part of your inspections (if they apply), and it'll smell bad. I'm not sure if a '94 has a post cat O2 or not, but if it does, you'll have issues. Just do it right, man; universal weld on cats are only $65 or so, and they flow as well as a straight pipe.
sorry- speeding up exhaust gas velocity-increasing the low pressure area behind the pulse wave and increasing the scavenging effect- o2 should theoretically lean out air/fuel slightly which isnt a bad thing at low rpm off idle 1200-1400rpm cruising 30-40mph cruising. sounds killer too....
Thank you. :)
I've got a cx racing header that goes to a 3" collectoe, no cats, both O2 sensors hooked up, 3" pipe over the frame, pro Flo muffler, perforated resonator parallel to the rear end with an exit out drivers side. Current set up but subject to change as it's a work in progress. Had an EMS system that worked good but loud inside the truck. This is quieter now but raps nicely at full throttle and I can hear the supercharger sing now.
Also my only CEL is 401 but my EGR is blocked with the header flange
Thanks guys - the universal cats are probably the way I'll go - not looking to get huge hp or mpg gains here - that's more of an engine swap forum than this - just trying to simplify everything and keep her running strong.
Also it would be a good time to relocate your O2 sensors up closer to the manifold. Remove the PAIR system and just plug them in where the air injectors went. It helps keep them from malfunctioning when you do any water crossing, or getting hit by rocks.
Im looking for ideas as well. I don't like how the cats hang down on my 93. Ive already disabled the PAIR. I have a leak around my manifold somewhere so id like to kill a few birds with one stone. Fix the leak, move the 02's, remove the cats and simplify the whole damn setup.
My 20yr old exhaust has developed some holes, so I ordered the Borla cat back replacement thru my shop to upgrade. I will probably pull the header and Y-pipe and inspect them and send them off to be jet coated.
