You have to consider that the spacing and number of supports takes into account two main things:
1) The total movement that needs to be absorbed/allowed to prevent breaking the exhaust pipe by cyclic movement alone. Too many supports doesn't allow enough movement and the exhaust breaks.
2) having enough support so that the weight of the pipe in between mounts doesn't bounce it around and cause cracking. Too few supports and the weight of the pipe breaks the sections.
If you can make decent guesstimates to keep it close to what was there for the stock pipes, you should be OK. On one hand, you could study it for months and do all sorts of hand calculations(we call that Engineer's Masturbation). Or you could eyeball it and be done in a weekend.
My thought would be that if you just do it and it breaks somewhere, fix it and move the mount. If it breaks close to a mounting point, you didn't have enough space between that mount and the next closest to the engine. If it breaks in between mounts near the middle, then there was too much space between the mounts. If it doesn't break, good job, you don't have anything to fix.
Also, if you were building a system from scratch, it is wise to use flex sections in the same location as original. The guys that designed the original spent a LOT of time deciding how to put them in the lowest-stress location to prevent them from failing early.
