Sounds like what has been said, it's inbetween the battery, the terminals, the grounds, or fusible links.
Is your battery loose or do you have the hold down still? A battery that shifts can beat up itself & all around it fast.
I'd run loose the body ground, clean & grease it, the same with the battery terminals, and if it's not sealed 2x check the acid level in your battery.
Shaking it might be a sign your low.
If it's still there give the fuse links a evil eye.
