I am in the process of removing the engine/transmission/transfer case from my 94 FZJ80. I have the head off, wiring off etc, pretty much ready to remove. I just need remove driveshafts, linkage etc. My question is what is the easiest way to remove this monster? I have pulled engines before but never one this long and never a 4wd. Usually I just remove the driveshaft, put a lift on it, remove the trans/engine mounts and slide it out. This looks pretty tough with the FZJ80. I am thinking about removing the transmission/transfer case first. I assume it must be easy since transmission shops do it many times a day but even with the head off of the engine it doesn't look possible to get a wrench on all of the bell housing bolts. Is there a trick to this, or special tools? Also when re-installing it all should I do it the same way?
I am ready to get it out and get the diesel sitting on my shop floor in!
Rusty
Rusty
