Engine Swap
I just acquired a 1978 Fj40 with a straight 6 The engine is bad. I would like to consider swapping it out for a v-8. is this a reasonable thing to do? If so what motor is the best fit? Easiest swap? For instance how would a Chevy 350 work? Easy or nightmare? I have a well equipped shop with a 9000lb lift and several engine swapps under my belt.
Thanks,
thanks for your replies. What the crap does "Search......Search mean? I am searching and this is part of it.
Lone Gunman, did you need an adapter plate to bolt the 350 to the Toy 4-speed?
Honk, you give a bunch of different engines, Thanks. Do you mean that these bolt right in or what?
Use the search button in the toolbar to find key words in posts. when you put in engine swap in there this will be the first link in there because it is the most recent with "engine swap" in it.
Warrn: "Have you seen my penis?" :flipoff2:
I hit the wrong button and posted that last message before i was done with it.
Honk, you list specifically 4 X 4s, are you changing out the engine, Tranny and Transfer case?
What about linkages, exhaust connections, Drive shafts, Motor Mounts, Tranny Mounts? Is all of that custom?
Phlyfish, I don't know what all that means. Sorry if I am stupid, but lets face it, I'm new here.
phlyfish said:
350/sm465 and Woody's plate to tcase
Chevy 350 with a SM465 transmission (4 speed, very popular)
Woody is some crack pot who posts here way too much :flipoff2:
his "plate to tcase" is an adapter plate for the SM465 transmission to connect to the stock toyota transfercase.
What they mean is to search the threads for similar discussions. This topic has come up alot.
To use a Chevy 350 with the Toy 4spd you need an adapter. I used the Adance Adapters Aluminum Bellhousing adapter. If you're gonna do mostly street and trails you'll like the 4spd. If Rock crawling and extreme wheeling is your primary use for the truck then you may want to consider the SM465. Check out the Technical Links for some really good info.
350 works good,but 454 has more grunt if its a mall cruiser.Not alot more work to install.More money for parts.Lots info here on mud.Get power steering makes life better with bigger tires.
Welcome Jim. Because SBC's are such popular swaps there is a lot of information already typed up on the topic ... the "search" is to prevent folks from having to retype all the details. In addition, there are a LOT of possible combinations of engine/tranny/TC, all depending on your use and budget.
This forum has a great deal about swaps in the Tech Section ... lots of good reading. In addition, go to: http://www.advanceadapters.com/
They DO NOT make the only adapters needed and they are not cheap, however, they do have a booklet you can purchase that explains many of the swap options for your cruiser.
Send me a note as you run into questions.
Rice
Thanks for the good information. I'll use the search feature, study the tech data and make a decision.
Just got the block, heads, cam and crank back from the machine shop for my son's lifted and locked '88 Jeep grand wagoneer. (Is Jeep a dirty word on this forum? Sorry) Looks like we have our work cut out for us for the next couple of weeks.
Thanks, again
Jim
Welcome, the newbie salute, :flipoff2:
Anyhow go with the SBC and stock 4speed, it's a very easy swap and can be done in a weekend or less, search ebay or this forum in parts for sale or post in wanted parts for adapters, there out there sometime and cheaper. Good luck.
Oh ya and don't use the "J" word here :mad:
No, I didn't list anything.
I posted the link to the excellent I8MUD (this forum) TECHNICAL PAGE whixh describes several options related to your request.
a fog is described in terms of density
