Engine swap question
Rosamond Ca.
I am thinking extremely long term here. My current 3FE just needs a good tune-up and it should be fine. It gets horrible mileage, but that's nothing abnormal I know.
In the long term as in a few years I may do an engine swap, and am looking at unique possibilities. I do want to keep it Toyota though. I have seen the 7MGE/MGTE swapped into mini trucks. I am thinking of this as an option for the FJ80. I have ZERO experience with this engine. I know enough to see the exhaust is on the passenger side, so routing the exhaust I foresee being somewhat of an issue. Beyond that I have no clue. Is there anyone with 7MGE/MGTE experience here? How does it compare to the 3FE in size/weight. Where is the power/torque curve? Is it even a viable swap option for the 3FE? Has it been done in an FJ80 before? I searched, but found nothing. Thanks
Are you talking about the Supra 3.0 V-6 engine ?
IMHO it has no place in a 80. You need a lot of torque at low RPM which this engine is not capable to provide. But if you are willing to swap a Tundra 5.7 V-8 then you have seen the light !!!!!
My buddy's Supra has the 7M-GTE. It's tuned pretty well, I drove it and was going 110 mph before the freeway entrance ended.
The 7M has it's place, but not in an 80, IMAMOO (In Mine And Most Others' Opinions). Go for the Tundra 5.7, or a 2UZ (4.7).
And, BTW, it's an I-6. :flipoff2:
This is about what I figured. Tons of HP and not enough torque where it's needed. It was just a thought. I am pretty sure that once I get the 3FE tuned up it'll be okay.
If you don't go Toyota if you swap, find this one.
"Does that thang got a Hemi in it?"
DOHC Hemi? as in 4 valves per cylinder? :eek:
How did they figure out the angles on those valves?
Given your window of thinking is 2 years........i seriously would hold off and consider the fact that Toyota will be bringing some form of Diesel to the US in the Tundra and who knows what other models down the road soon thereafter. Im guessing 50% of the people here will be seriously considering offloading their 80s....while the other 50% will be considering how to shimmy whatever V-8turbo diesel that makes its way here into their 80. Im also betting that the nicest diesel option in 2 years will be the mercedes Sprinter diesel engine married to an h55f. -nostradieseldamas.
