Engine Swap Options
NEW JERSEY
Website
pg.photos.yahoo.com
The Problem Is Time. I Have To Get The Engine Out Asap And Into Its New Home. That Is Where I Will Clean It Up. I Am Trying To Get It Out Without Taking Everything Off The Engine. I Just Want To Take The Engine And Trans Out In One Shot Do A 180 And Drop It In The New Frame. I Have All New Mounts (eng/trans) So I Do Not Have To Reuse Any. I Am Having Mixed Thoughts About Doing It This Way. Should I Just Take Off Everything That Is Attached To The Engine? Has Anyone Pulled The Engine/trans With Everything Attached? Need Some Guidence With This.
Thanks
Soory About Caps @ Office
Should work with everything still hooked up. I did with my '73 F and worked fine. Just undid the throttle linkage, a few misc wires, exhaust and radiator hoses. Some will argue that it is better to do the motor separate from the tranny, but most will say it is easier to leave them all as one and lift and go.
Also, you'll have to take the radiator out and drop the front bib...maybe even take it off....only a couple of bolts hold it on. Just as a reminder, when you drop it down, be careful as the headlights will protrude and want to get cracked on your frame rails/bumper. Don't ask how I know. :)
I'd have a power-washer and some degreaser nearby and give it a good clean/blast while it's on the hoist. Otherwise, I don't see why you'd want to take it all apart if it's in good running condition.
I'd take off the whole front end on the destination vehicle.
did get the whole front end off today and drained the engine oil and rad. will take the rad off in the am then start unbolting everything. anyone know where i should start unbolting? :frown: :confused: :grinpimp:
First would be the radiator supports. After that, there are several small bolts that keep the bib on. As I remember, there are two on each side of the bib attached to the fendor apron and two/three attached the fendor on each side.
After that, unplug the head lights and the bib will swing forward towards the front bumper. There are two bolts holding that hinge to the bib and disconnect there. After that, you've got the motor mounts and disconnect the drive-shafts if you're going to pull everything out at once.
Again, there aren't a ton of bolts to worry about. You'll be surprised how quickly and easily the front end comes apart. Just don't lose any bolts :) And take some pics of how things are together if you feel you won't remember.
One other piece of advice, make sure your engine hoist has the legs fully extended. The engine/tranny/t-case all together is extremely heavy and if the legs aren't extended all the way out, the hoist will want to tip on you.
True dat on the headlights. They line up exactly on the tow hooks that bolt on the top of the frame.
The CG of the engine/trans is very close to the back of the engine. If you don't have the crane hooked up back there the end of the trans will swing down and hit the floor when you lift the thing off the mounts. The tip of the crane that I was using was almost touching the hood when I was replacing the eng/tran.
If you have some extra wieght it would be good to put it on the crane base because the eng/trans is one heavy mo-fo.
i took off the whole front, now i am in the process of marking everything and where it sould go when i put it back together. but i really want to take it out with as much as i can on it. but what is going to be a bigger pain in the *%$?
Pull gear shift and transmission tunnel and tranfer shift,Unbolt the drive shafts,disconnect exhaust, pull bolts out of front and rear motor mounts, hook hoist to rear end of chain that you put on front and rear motor hooks ,you have to pull the air filter assembly so you can see the rear engine and transmission come out as you slowly raise the hoist. you should have a friend to help you swing,push, guide and call you names while you lift the eng/trans and watch for hangups and snags. As the E/T comes out, roll the cruiser back alittle at a time until clear. Leave as much as you can attatched to the engine...just watch for snags as you pull it out. You didn't need to drain oil... but you got an oil change
Putting it back in is straight forward and you'll be surprised at what you'll remeber of what goes where...Good luck it's kinda fun!
Ditto on what Hatchman said. Utilize a friend and you're good to go. When I did mine, I kept the fenders on the rig, but you've just given yourself more room. The front bib and radiator are the biggest things that you need to remove.
Good luck and take it slow as things will want to get snagged. One thing that I don't think was mentioned was the speedo cable as it is attached to the t-case. Other than that, just go for it and anything that sticks, unhook :)
