Engine starting issues, any ideas?
Anthony.L
Looking for the end of the road...
Federal Way, WA
I have a 97 Toyota LC and having some starting problems. I've owned this FJ since last May and it has ran flawless from then to now. However the past month it's started having occasional starting issues. I will get in turn the key over, get one click, and nothing. Starter does not turn, engine does not turn over or try to fire. Before I would turn the key off, then try again and it would fire, although a little hesitantly. Yesterday I got in and now it will only click, will not start period. I first assumed the battery was going bad, so I replaced it with a Optima yellow top. I've had Optima's in all my other vehicles and figured now was a good time.
After replacing the battery I was able to get it started, but after a couple tries with the exact same behavior as before.
Now the strange part, it seems that if I press down on the brake pedal hard as I can the engine is more likely to start. This isn't 100% effective, but right now the only time it will start is with me pressing the brake pedal hard.
FYI, this problem did start happening when the weather began getting very cold (below 30-40) here in the PNW. This was another reason why I suspected the battery was dead or dieing, but that didn't resolve the problem.
Thanks in advance for the help!!!
Unless the starter has been submerged in mud/water, I'm sure the motor itself is fine, I would suspect the starter solenoid contacts. Rebuild kits are cheap from Toyota and are a one :banana:job.
Some related reading......
Toyota/Chrysler/Mitsubishi - Nippon Denso Starter Solenoid Repair
How old is the starter?
Mileage on the vehicle?
Condition of battery cables and ground connection?
