Engine rebuild
Main block shouldn't take more than a day. The biggest wild card is how long the machine shop will take.
A buddy rebuilt his in about a week of working on it in the afternoons. It was his first one and it runs great.
One of the biggest things is making sure you've got all of the parts you need laid out lined up all of the old stuff thats going back on cleaned and painted and making sure that you have EVERY tool and gasket that you might possibly need...I've found that when doing an engine tear down and rebuild if I haven't taken the time to prepare and walked myself through each step and thought about what I needed that I ended up spending twice as much time runnning back and forth to the parts store needing to stop and prep parts....yadayada...you get it, but! when I have taken my time and prepared properly it takes no time at all all that said I;ve spent two week doing a rebuild and then I've spent two days on the two day The first day I took everything to the machine shop that needed to go and dropped it off then went home and preped (keep in mind I had already called and set this up with the machine shop first) the next day me and my dad put the engine together in four hours after he got off work and this was a pontiac 400 big block so more gaskets and two heads to contend with so time is up to you and remember if your doing it right you don't have to rush to get it done quickly
I hope this helps ya
sorry it's so long winded
-Brandon-
I have rebuilt a lot of engines and one thing I have learned from this is that it is easy to screw up. Because of this, I would just have your machine shop assemble the long block. They have done a lot of them and they will warranty their work if they assemble it. It doesn't cost a lot; maybe $300-400 extra depending on your local labor rate.
