Engine rebuild
Opelika, AL
I have a friend that does a lot of drag racing. I asked him who builds his engines and he pointed me in the direction of a guy that is the most amazing engine builder around. I haven't talked to this mechanic about my Toyota yet but I was wondering what the general consensus would be to trust someone like this to build your engine not knowing how much experience they have on Toyota's. Is a Toyota engine that much different from other engines besides the obvious reliability?
While it's no SBC, I don't think he should have any problems rebuilding it. It's still an internal combustion motor. Make sure that he keeps the cams "timed" correctly with the motor and understands how to adjust the valves, takes shims. The FSM will walk you through all of that. Let us know how it goes and what he does. Get your gasket parts and all of the little stuff, which he will know exactly what you need from Cdan. Happy building.
Jack
Howdy! It's probably worth checking out, but this guy is a RACING engine builder, not a TRACTOR engine builder. There are a lot of differences. Money is one of them. He may refer you to someone who is more into LOW performance builds. John
He does do race engine builds but also does the D. Drivers also. I talked to Man-a-fre awhile back and they said the heads needed to be hand lapped. I'm thinking they're talking about the way that you bolt the head down. Assuming this has to do with the headgaskets failing and the way you bolt it down keeps the head from warping. I'm sure this guy will know what they mean.
Howdy! I have only heard the Term "hand lapped" used in reference to fine tuning the fit between the valve face and the seat. Sounds like this may be your builderman. John
Lapping is not the way they bolt the head down. John is correct.
