engine rebuild kit?
Houston
Toyota 4.5L 1FZFE Engine Kit Landcruiser
Has anyone been the guinnea pig for these guys? Picked up a 12/93 with rod knock or piston slap and 185k miles, body and interior is too clean to part out so will fix the engine and let parents drive it. Diagnoses of the engine failure seems to be low or contaminated oil due to an old oil cap that must have fell off and that is laying on the front skid-shield under the radiator... (Owner mentioned a bad oil leak that was fixed, didn't have the heart to ask how much he paid for them to fix it...) Will take pics of the teardown and such...
Seen another post where Toyota 1mm over pistons and rings were right around $500 a set, still need bearings/rod bolts, head bolts, machining, valve jobs, gaskets, and sealants.... Revolution4ever is advertising H beam and 4340 forged/billet rods and cranks a long with a 1FZ stroker kit in case someone else is interested....
I do have a 4BT laying around but don't want to swap that in as it would be PITA and more expensive than a rebuild. Would be nice to convert to a '98+ 1FZ-FE but i'm sure it would be cost prohibitive although a cast iron 1FZ head would be nice to bolt on if one can be had from somewhere...
