Engine Oil
Tri Cities, Washington
Ok, so I have read through several threads that talk about engine oil and it seems there are a lot of different thoughts on this. Specifically I am looking for thoughts on engine oil for higher mileage rigs. My 91 FJ80 has 245K on it right now. I live in an area that is prone to temperature extremes. Summertime highs can and do hit 115 degrees. Wintertime lows can be as low as negative 5 degrees. Some of the threads get away from the original factory recommendation and I get the fact that oil technology has changed dramatically since 1991.
What does everyone think is a good all around oil and filter?
Thanks!
Does the 3FE use the same 5W-30 as the 1FZ? If so just pick out whatever bottle looks prettiest to you. You can't go wrong with any of them.
X2 on the Rotella. I broke down and put it in my 3FE last oil change and it's really happy now.
Oh and for filters, I don't use anything but Wix or OEM in all of my vehicles.
10w 30 here for my 3FE 218,000 miles so far.
Over the road trucks run fleet oils like Delo, Rotella and delvac 1300 and survive 2 million miles under constant load. That's why many enthusiasts of all types of motorized sports run these oils no matter the engine. Very robust additive packages you can count on for extended oil change intervals. I personally have run Delo 400 LE in my 2005 cummins 20k and Blackstone Labs said it was still good to go. This is mineral oil with a top of the line filter. Visit Bobistheoilguy.com for more info than you care to know. Oil is now a commodity unlike when you grandfather bought his new Ford in 1940.
