Engine miss
biloxi ms
My 04’ LX has developed a hard engine miss under acceleration at about 3200 rpm. No check engine light or codes when scanned.
In the last 10-15 k miles I have replaced upstream O2 sensors, plugs, coils, MAF, fuel pump, fuel filter and had the injectors cleaned.
Any ideas where I go from here?
If it can be reproduced reliably have someone drive with techstream connected and let them check real time data for anything unusual that would explain the problem. This would be the easiest way to go about it IMO.
If I only knew someone near me I would do that! Thanks for the response
Were the injector spray patterns and flow rates tested when they were cleaned?
are you sure your coil packs and spark plugs are Genuine ? If you bought them anywhere other than a Toyota dealer, they're probably not
This!
Spark plug yes but the coil packs a denso bought from a reputable parts outlet. My thoughts are that it’s fuel related since there are no codes
Hard to believe it’s coil packs. My experience and others have said that coil packs either work or not. Not occasionally misfire
I have had misfires where the spark plug loosened a couple of times and fouled the coil packs. I would open and inspect each coil pack and spark plug to make sure.
Flow patterns yes but I do not know about pressure testing.
I have experienced an intermittent misfire that eventually turned into a consistent misfire and ended up being injectors. Resistance tested fine initially but eventually drifted out of spec.
I had two ignition coils dying and they would do exactly that. First intermittent misfire only under certain conditions. Then they are gradually getting worse, amount of misfire increases and CEL comes on.
From my original post about my engine miss under acceleration at 3200 rpm.
I took the LX to run some errands and I could not make it misfire at all. It shifted at 5k out of low gear perfectly and in pushed it hard without misfiring at all. This was all just around town but it did get to operating temp. When I noticed the misfire happened before it was on longer drives in outside temps near 100.
I’m tending to think it’s a coil pack not injectors.
Any input please?
Multimeter and FSM. Google is your friend.
Thank you!
