Engine Knocking ????
Granger, IN
Halfway through a 150 mile trip on Christmas day in the 1993 fzj80 (242000 miles) I noticed a knock coming from the engine. Once home I changed the oil (it was pretty low) and the knock seemed to smooth out some but it is still there. Knock is constant but speeds up with acceleration. seems to be in the top end of the engine. I'm pretty broke (just graduated college) and don't have alot of access to alot of tools.
Any suggestions on where to start diagnosis or what it might be?
I have looked at as many engine knock threads as I could. most seemed to be referring to intermittent knocking or only on start-up, not constant knocking
How low is low?
Is it a fairly slow and steady knock, or more like a chatter/rattle?
How low is low?
low is like 2 quarts low
it is definately steady and speeds up with acceleration. I would describe the sound as a knock or loud click
I don't have too much experience with bottom-end knocks...thankfully and been awhile since I've spent much time trying to diagnose a rod knock...that said when does it knock? On start-up, going away after building oil psi? Can you get it to knock in neutral when revved up and once the engine speed begins to decrease? We need a little more detail, but an engine knock from the top/bottom is never a good thing. But if I had to guess, I'd say we are talking rod bearings...i.e., you need a short-block...maybe...hope I'm wrong for your sake.
I wish you luck my friend.
And don't beat yourself up on the two quarts low thing...these motors have a huge capacity, I don't think you starved the sump for oil, I just think if it goes the way of bearings that she was tired and threw in the towel.
always
does not go away. ever. (quieter while idling)
yes
I'm afraid its shot. how difficult is it to replace bearings? Are we talking engine swap time? Do I keep driving it till it stops?
Thanks for the help
Notice any difference on oil pressure gauge? If you have a really bad rod knock, the oil is leaking profusely from that bearing and you should see a bit of a pressure drop.
torque converters and/or bad flex plates can make sounds exactly like a rod knock.
I'd get to an auto parts store, buy a mechanic's stethoscope and start listening. Harbor freight has them for $6.
There's tons of youtube videos of rodknocks, also on google, may help you ID the noise your engine is making.
I have a '93 in which had constant knocking, ended up being the piston was rocking in the bore due to overheat or running low on oil if not both. Guess that the piston expanded due to heat and locked up causing gallings and extra piston clearance which turned into a rocking motion. .5mm overbore cleaned things up I think.
My '94 has a very distinctive metallic sound int he front of the engine which sounds like the oil pump idler gear hitting the crankshaft drive gear due to an excessively worn oil pump idler shaft bearing, aka unobtanium unless custom made... Or at least that's what I think it is anyways...
