Engine High Idle and Spark Knocking
Charlotte, NC
It has gotten hot here in the south so I have started running my AC some. I have noticed that the engine has a real bad spark knock at real low speeds and seems to go almost away when reaching higher speeds. My engine will also idle high once it gets hot....maybe about 1500rpms. Also, seems to be burning rich when I'm sitting as I can smell gas pretty strong. Any ideas what is going on?????
What year? Any Codes?
If "spark knock" means pre-detonation pinging, then you have a problem that will eventually destroy the engine. Pinging happens when hot, and also when the fuel trim is on the lean side. Happens mostly when you first touch the throttle with light foot pressure. If your high idle is caused by a vacuum leak, this would mean the fuel trim is real lean due to unmetered air entering the intake. Could very well be carbon build up inside the cylinders and head too.
But first, fix the idle issue. Check the air intake tube for cracks, and the hoses going to the throttle body from the valve cover (PCV valve system) for cracks too. There are plenty of small vacuum rubber hoses under the intake to inspect also.
Is your idle high the entire time, or only when the A/C comes on? The idle should raise up when the A/C comes on.
